Can someone post a pic of there wires on the main relay....
must be from a 90-91 civic
says 1 should be: Green/Black ----Mine is: Yellow/ White
says 2 should be: ----
says 3 should be: Blue/ White ----Mine is: Yellow/Black
says 4 should be: Black ----Mine is: Blue/White
says 5 should be: Yellow/Black ----Mine is: Black/Yellow
says 6 should be: Black/Yellow ----Mine is: NONE
says 7 should be:
says 8 should be: Yellow/White ----Mine is: Green/Black
Car was at a shop a while back, and i just got into it....is it possible they messed up the pins?? wtf
Modified by HatchBox at 4:52 PM 3/11/2006
says 7 should be:
the diagram is from 91 CRX manual - for SI/HF here is full page (if you can read it)
here is the DX (Honda called it STD back then)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wood »</TD></TR><TR><TD CLASS="quote">Is there a copy of the USDM CRX manua;l somewhere on line? If so could you tell me where?</TD></TR></TABLE>
there is a site to download the USDM CRX manuals - it is a little tricky, but here is what you need to do:
if you are using Microsoft Internet Explorer as your browser (unless it is older version) you won't be able to access the right place on the site, so best thing to do is use Netscape as your browser (i know it works) - if you don't have Netscape browser, you can download it for free - go to http://www.quickhonda.net - enter site - go to menu at upper left and click on "The Garage" and drop down to "Service Manuals" - click that and then you can download the Zip files - the manuals are in .jpg format
Thrillhouse
Audio / Security / Video
Jul 13, 2005 07:17 AM
