skunk2 Im on LS High idle problems
Old Mar 11, 2006 | 11:42 AM
importdude2000's Avatar
Default skunk2 Im on LS High idle on colde start problems
well its the problem is its installed on a 90-93 integra
which has FITV on IM
with the Skunk2 im its removed
so i bypased it
but the problem i been having is
cold startup is 2500rpm and is cold for 25 mins!
donesnt turn warm until long time
whats the problem?
ppl said no FITV should not HOLD IDLE
my **** holds it fine..
wahts seems to be wrong?
imma grab a 94-95 tb with fTIV and see waht happens
Old Mar 11, 2006 | 11:03 PM
aynone?
Old Mar 11, 2006 | 11:49 PM
95TegSE's Avatar
Default Re: skunk2 Im on LS High idle on colde start problems (importdude2000)
I have the Skunk2 IM on my LSVTEC and it idles around 2000-2200 cold. I think it's normal, since my car runs fine with no problems and idles at 750 when warm.
Old Mar 12, 2006 | 12:34 AM
JDM turbo DC's Avatar
476 whp / 323 tq @ 17 PSI
Default Re: skunk2 Im on LS High idle on colde start problems (95TegSE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95TegSE &raquo;</TD></TR><TR><TD CLASS="quote">I have the Skunk2 IM on my LSVTEC and it idles around 2000-2200 cold. I think it's normal, since my car runs fine with no problems and idles at 750 when warm.</TD></TR></TABLE>
you dunt have anything to worry about, the car revs high when cold to maintain higher oil pressure so you can get oil runnin throughout the engine until warm.
Old Mar 12, 2006 | 03:06 AM
my **** stays at 2500 for 20mins?
**** if i leave it til the goes to idle it takes 30 mins
Old Mar 12, 2006 | 04:45 AM
Sam92Teg's Avatar
Default Re: (importdude2000)
Sounds like your thermostat isn't closing enough, so the engine doesn't warm up quickly.
Old Mar 12, 2006 | 04:48 PM
Jake1220's Avatar
Yep sounds like thermostat, I replaced mine the other day. Your water should heat up to operating temp fairly quickly. Mine does within 5-10 mins.
reg_lus
Jul 17, 2022 10:03 AM
UK_Luder
Jul 24, 2007 09:08 AM
Spracer03
25
Dec 13, 2006 10:19 AM
MenaceL.A.671
Feb 20, 2006 11:00 PM
duberz
Oct 14, 2004 03:03 PM
