400 dollars for 17 inch bronz/copper rims with tires... is it a good buy?
Old Mar 11, 2006 | 11:05 AM
V6 Cylinder's Avatar
Default 400 dollars for 17 inch bronz/copper rims with tires... is it a good buy?
there's this kid offering to sell them to me, they got a few minor scratches, very small scratches, tires are very thin and appear to be brand new. 400, should i cop them?
my 95 accord is a dark, dark green, I'm not sure if the color of the rims will blend with the color of my car. pease advice.
Old Mar 11, 2006 | 11:25 AM
philadd's Avatar
Default Re: 400 dollars for 17 inch bronz/copper rims with tires... is it a good buy? (V6 Cylinder)
I can't tell you if it's a good price or not. You haven't said what kind of rims they are. I'm not considering the tires, b/c you said they're "very thin". I'm under the impression that the tire is sized for Civics (40 series instead of 45, etc).
Generally speaking though, for a set of rims + tires, 400 isn't that bad. I'm iffy about the scratches though.
Old Mar 11, 2006 | 11:29 AM
the scratches were hard to see. the rims were on an integra, the bubble eyed ones. i don't know much about rims, but I'm going to call the guy and ask what brand they are , etc. do you have any other wuestions that i should ask this guy about the rims?
Old Mar 11, 2006 | 12:04 PM
MilanoLude's Avatar
400 bucks sounds like a good deal with tires... if the tires have good tread and the rims are good condition then go for it. If they were on an Integra, make sure they have a univeral 4 lug pattern.
Old Mar 11, 2006 | 12:13 PM
philadd's Avatar
Default Re: 400 dollars for 17 inch bronz/copper rims with tires... is it a good buy? (MilanoLude)
The tires are most likely too small for your car. If it was me, I'd get new ones. Accords use a larger diameter tire than Integras and Civics. While 'Tegs and Civics generally run 205-40-17, Accords usually run around 215-45-17.
Old Mar 11, 2006 | 02:02 PM
vivaladan89's Avatar
i agree with you ^^ but if his car is lowered thats a diff story, ive seen some lowered hondas that couldnt take the full size of a normal accord tire. as for bronze rims on a green car dude no offense and its all about what u like but in my opinion your putting ugly on uglier.
Old Mar 11, 2006 | 03:46 PM
P_Adams's Avatar
The Integra uses a 4x100mm bolt pattern, as opposed to the '95 Accord which uses a 4x114.3mm bolt pattern. On the face of it, they won't fit.
IF (However) they are dual-drilled (8 holes as opposed to 4) they may have both bolt patterns. IF that is the case, the rims are a "Go".
Tires? anything smaller that 205's will not work well on an Accord. The cars got a fat ***, and needs all the traction it can get for good road handling.
If you can get past the color, $400/set of 4 17" wheels isn't an unreasonable price. I'd certainly consider it.
P
Old Mar 11, 2006 | 03:47 PM
philadd's Avatar
Default Re: (vivaladan89)
I'd rather raise my car back up some then have to use smaller tires, but that's just me. Running smaller tires will also cause your speedo to be off a little.
Old Mar 11, 2006 | 03:51 PM
P_Adams's Avatar
Default Re: (philadd)
Not to mention the "Roller Skate Syndrome". What next? Hydraulic suspensions for Honda's?
P
Old Mar 11, 2006 | 08:54 PM
FallenAngelHIM's Avatar
if they fit, buy them. i had an offer for racing harts with tires for 600 but i'm DEAD broke.
stdefhatch
Apr 5, 2016 08:32 PM
Honda civic ex1
Wheels
Dec 21, 2010 01:37 PM
rsx-lake
May 5, 2003 08:16 PM
