Radiator and a Turbo in a CRX, Here's how! Lots of pics
Got my Neukin manifold and had this in mind from the start. Alex at Neukin worked with me and hooked me up with a kick *** manifold/3inch DP and Turbo. After lots of measuring and thinking I decided to mount the radiator under the t-bar.
First I cut the bracket that the condensor mounted to out.
This is the C&R radiator 3/4 style btw
next I mounted the Radiator under the t-bar
Here is a peek with the t-bar installed
here is the mount setup, used a fabbed up angle aluminum with rubber bushing to take some of the shock of a lowered car. bolted in and using the radiator lower tabs.
Another view, sorry I was standing on my head, you can see the tab coming through the bracket.
Top view with everything mounted. Nice and clean
Front View
May not interest all but thought I would share. Should be running soon!
Front View
what all did u have to do to make this work im thinkin boiut doin it instead of payin over 300 for a pwr rad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrtoastyjr »</TD></TR><TR><TD CLASS="quote">how are you planning to get that rad cap off? take the t bar off?</TD></TR></TABLE>
a lil bit more of custom fabbin would solve that problem give it a try b/c that cap looks to be a PITA unless you have another cap in the system somewhere not seen
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16_madman »</TD></TR><TR><TD CLASS="quote">a lil bit more of custom fabbin would solve that problem give it a try b/c that cap looks to be a PITA unless you have another cap in the system somewhere not seen</TD></TR></TABLE>
How often do you actually pull the cap? Usually you fill and check the overflow tank unless doing some work to the cooling system, then it looks like 2 10mm bolts and it's off and out of the way. I haven't pulled my radiator cap in months, 2 bolts every few months doesn't sound like a big issue.
full races pwr radiator fits with some turbo kits, not all, including theres wit a 3in downpipe.. nice setup though..
Full races radiator is not for turbo setups, check their website.
And this is a larger radiator and I already own this one.
4 bolts isn't that big a deal, and its better to me than the gangster lean EG Radiators.
If you don't like it no biggie, I know there are lots of people that want options.
i agree with u if ure talking to me, im been looking 4 a way to mount mine. i have been through about three rads since i started this project, and seening what u did gives me more ideas.. i like ure setup, congrats .. and as far as taking 4 bolts every once in while , i see no problems with that...
Its all good, just sharing ideas with those in need. I've gotten more than my share from here so I try to give when possible. I can deal with the HT haters, lord knows I teach 5th graders for a living.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nowentaquit »</TD></TR><TR><TD CLASS="quote">Thats new to me!
x2
props here
</TD></TR></TABLE>x2
props here
[QUOTE=88crxvtec]Full races radiator is not for turbo setups.
[QUOTE]
ok thats why i run one on my setup..
good reasons, hell if u own that rad already and can make it fit great.
[QUOTE]
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crxvtec »</TD></TR><TR><TD CLASS="quote">Full races radiator is not for turbo setups, check their website.
If you don't like it no biggie, I know there are lots of people that want options.</TD></TR></TABLE>
really..i was usiing one in my setup....could you pm what you have heard about it.
Setup looks good man...boost and full length raditiator
i pop my cap to refill it b/c it leaks
i'm in the market for a new radiator but i'm leaning towards the eg setup w/a x member to prevent gangster lean
