Restore - Engine lube oil question..
Old Mar 10, 2006 | 11:10 PM
..::91TEG-G2::..'s Avatar
Default Restore - Engine lube oil question..
I just picked some of this up from walmart for my 145k+ 91 integra.. just curious to know if any of you have had experience with this product and what was the outcome.. yes i know about seafoam and what it can do. i'm just curious about this product. please give me some of your feedback. thanx
Engine Restore Lubricant Website
oh btw, i havent put it in yet..
Old Mar 10, 2006 | 11:30 PM
b20integrapower's Avatar
Default Re: Restore - Engine lube oil question.. (..::91TEG-G2::..)
i dont see how it can work..
Old Mar 10, 2006 | 11:32 PM
Dartanian's Avatar
I wouldn't throw that **** in my engine. If you are burning oil, it is just a bandaid. Fix the problem instead of masking it. If it isn't burning oil, leave it alone.
Old Mar 10, 2006 | 11:41 PM
FalkenSiR's Avatar
Default Re: Restore - Engine lube oil question.. (Das Schmoo)
Lots of people I've talked to put it in their engines every oil change. Seems to work. I use it also.
Old Mar 10, 2006 | 11:55 PM
Takumi Fujiwara's Avatar
Default Re: Restore - Engine lube oil question.. (fast88std)
My car was burning oil... later found out to be a small piece missing from my valve. You must find the root of the problem. That item did nothing for me.
Old Mar 11, 2006 | 12:12 AM
CNSK's Avatar
always wonder what it can do......i might try it...losing compression on cylinder #3....btw it has 220k miles....ill try it band aid it....
Old Mar 11, 2006 | 07:51 AM
Default Re: Restore - Engine lube oil question.. (CNSK)
for the record, im not burning oil, im doing this for all the other reasons this thing is used.
and its not some off brand bullshit, it has probably more popularity than seafoam..
well i'm going to be driving around today, so this morning, i'll throw it in, start up the ride, let it sit for a few mins to warm up, just so the stuff can circulate through out the engine, and be on my way
any others have any testimonys?
TIA
Old Mar 11, 2006 | 08:36 AM
aeon's Avatar
i was using that for awhile, but then i just stop... nothing is wrong with my car though.
Old Mar 11, 2006 | 09:05 AM
92integraVTECgsr's Avatar
ya dont bother.. just wasting more money buying that ****.. either fix the problem, or just leave it and keep an eye on it.
how bad are you leaking oil? if you're not leaking or burning oil, then just leave it.
run a bottle of Seafoam through your engine. that really helps.
Old Mar 11, 2006 | 09:10 AM
Default Re: Restore - Engine lube oil question.. (92integraVTECgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr &raquo;</TD></TR><TR><TD CLASS="quote">ya dont bother.. just wasting more money buying that ****.. either fix the problem, or just leave it and keep an eye on it.
run a bottle of Seafoam through your engine. that really helps. </TD></TR></TABLE>
yeah but i keep hearing about how it might not help, because the carbon deposits are keeping the cracks and **** filled and keeping the compression up, then if you flush all that **** out, you might risk loosing compression.. thats why i thought i'd try this.. its only 4 bucks..
but what i will do is, put this is now, run it until my next oil change, since i just got one, then wait until my next oil change and put it in right before i take her in
Old Mar 11, 2006 | 09:14 AM
.brian.'s Avatar
your integra is a 6 cylinder? pics?
Old Mar 11, 2006 | 10:27 AM
Default Re: Restore - Engine lube oil question.. (.brian.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .brian. &raquo;</TD></TR><TR><TD CLASS="quote">your integra is a 6 cylinder? pics?
na its actually a V10
Old Mar 11, 2006 | 11:46 AM
vtecmissle's Avatar
It doesnt do anything but thicken up the oil .. THis leads to more varnish and ash deposits in the engine. Go to http://www.bobistheoilguy.com and research this product. There are a lot of intellegent people post this there and talk to an expert about it. Id recommend auto rx a product hyped on there. It will thouroughly clean deposites wherever their is oil . There is independant testing by users also. you cant buy it in stores. Use it and test it and review it. Seafoam is also a joke. I used it and then took apart an engine. All it might have done is washed the oil off my rings into the combustion chamber where it smoked and some out of the intake manifold. No professional race car team uses the ****. No automanufacture uses the **** and using it might just void your warranty. This restore **** does nothing either. Untill independant testing proves otherwise its all smoke annd mirrors. Dont rev your car on restore when it gets hot it turns brown and gums up the engine parts. Put some in a pan and cook it on the stove. Ventialtion will be necessary this stuff is junk.
Old Mar 11, 2006 | 12:52 PM
then tell me this ht professionals.. what CAN you guys vouch for that is a pour in product other than seafoam..
no no no engine rebuilds, i dont have the money.. im not going to do anything drastic to my engine, just want some pour in **** that MIGHT hopefully do some restoration..
but again, i'm still going to try this can of ****, at least once.
oh and is it THAT bad to put .5 qt's of "oil" over? my dip stick reads exactly to the top dot, where it should.. but will this stuff be bad if i pour it in being .5qt's extra?
Old Mar 11, 2006 | 04:07 PM
anyone?
Old Mar 11, 2006 | 05:30 PM
Uncle Willie's Avatar
I must say that RESTORE IS A KICK *** PRODUCT. My friend uses it on every oil change on his 92 ford f-150 and it works amazing. Since the truck has 2XX,XXX miles on it, compression is pretty bad. He can always tell when he needs an oil change because when this stuff wears off, his motor seems sluggish. Then he changes it with maxlife and adds restore, vuallah, motor runs great again. I highly recommend this product to people who have low compression.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecmissle &raquo;</TD></TR><TR><TD CLASS="quote">It doesnt do anything but thicken up the oil .. THis leads to more varnish and ash deposits in the engine. Go to http://www.bobistheoilguy.com and research this product. There are a lot of intellegent people post this there and talk to an expert about it. Id recommend auto rx a product hyped on there. It will thouroughly clean deposites wherever their is oil . There is independant testing by users also. you cant buy it in stores. Use it and test it and review it. Seafoam is also a joke. I used it and then took apart an engine. All it might have done is washed the oil off my rings into the combustion chamber where it smoked and some out of the intake manifold. No professional race car team uses the ****. No automanufacture uses the **** and using it might just void your warranty. This restore **** does nothing either. Untill independant testing proves otherwise its all smoke annd mirrors. Dont rev your car on restore when it gets hot it turns brown and gums up the engine parts. Put some in a pan and cook it on the stove. Ventialtion will be necessary this stuff is junk.</TD></TR></TABLE>
NO **** race teams dont use it. THIS PRODUCT IS FOR BAD COMPRESSION VEHICLES. Race teams do not use motors that have bad compression, hence they dont need to use this product.
As others have said before, this is only a bandaid. I have to say it is one hell of a bandaid. If you need to use this product, then you know ur motor has pretty much one foot in the grave. If you cannot afford to rebuild ur motor, then definitley use this product.
RESTORE
Old Mar 11, 2006 | 09:00 PM
CNSK's Avatar
Default Re: (..::91TEG-G2::..)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ..::91TEG-G2::.. &raquo;</TD></TR><TR><TD CLASS="quote">then tell me this ht professionals.. what CAN you guys vouch for that is a pour in product other than seafoam..
oh and is it THAT bad to put .5 qt's of "oil" over? my dip stick reads exactly to the top dot, where it should.. but will this stuff be bad if i pour it in being .5qt's extra?</TD></TR></TABLE>
try it and call it a day.....see if it will work or not......nuf said...
Old Mar 11, 2006 | 09:09 PM
Default Re: (CNSK)
expletive people!!! i took the **** back too! oh well, my oil is filled up to the top dot on the dip stick, so .5 extra probably wasnt a good idea, i'll for sures use it on my next oil change..
Old Mar 13, 2006 | 12:54 PM
Gs-Rx's Avatar
i dont think any kind of oil or engine lubrication that you pick up at walmart should go in your engine
Old Mar 13, 2006 | 03:02 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Restore - Engine lube oil question.. (Gs-Rx)
you can buy mobil1 at walmart...
h22lude317
Jan 9, 2009 08:39 PM
YoshiiEK
Jun 18, 2008 11:44 AM
Corruption
Jun 4, 2005 06:49 PM
Arsenal
Apr 19, 2004 04:10 PM
SuperMan19
Nov 5, 2001 03:24 AM
