ecu help
Old Mar 10, 2006 | 07:46 PM
brandons 95ls's Avatar
Default ecu help
i have a 95 ls and i need to reset it and i dont know how to do it.. btw were is the plug to hook up a scanner to the car. thanks
Old Mar 11, 2006 | 12:14 PM
Default Re: ecu help (brandons 95ls)
bumb
Old Mar 11, 2006 | 06:31 PM
anybody
Old Mar 11, 2006 | 06:32 PM
Dogginator's Avatar
Daisy... Daisy...
You pull a fuse in the under hood fuse box for 10 seconds. I think the fuse is labeled backup.
Old Mar 11, 2006 | 06:46 PM
loudassVTEC's Avatar
Default Re: ecu help (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">You pull a fuse in the under hood fuse box for 10 seconds. I think the fuse is labeled backup.</TD></TR></TABLE>
Either do that, or unplug your ECU, and let it sit for a few minutes. It's much easier to just pull the ECU fuse under the hood though.
Old Mar 11, 2006 | 07:03 PM
iH8RICERZ's Avatar
Default Re: ecu help (loudassVTEC)
to reset the ecu, you can either pull off the negative terminal of your battery for 5-10 minutes or pull the ecu fuse like somebody has already mentioned
Old Mar 12, 2006 | 07:21 AM
Default Re: ecu help (iH8RICERZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ &raquo;</TD></TR><TR><TD CLASS="quote">to reset the ecu, you can either pull off the negative terminal of your battery for 5-10 minutes or pull the ecu fuse like somebody has already mentioned</TD></TR></TABLE>
That's another way, but I didn't mention it, because a lot of people have to put in a code to get their radio to work again. Most people don't know it, and have to go to the dealer.
Old Mar 12, 2006 | 08:26 AM
Erik95LS's Avatar
What these guys have said. Any will work.
Do you have a check engine light? Over on the right side of the dash near where the ECU is theres a little green plug. You just need to bridge the two wires with a jumper and that will show you the code through the check engine light.
roseda91
Aug 12, 2007 01:25 PM
luvinmyGSR
Jun 12, 2006 10:44 PM
Mandeep
Aug 21, 2005 04:53 PM
gutterslide
Jun 3, 2005 09:44 PM
Layziebtnh055
13
Apr 20, 2004 05:38 AM
