Check Engine Light - Cat Converter
Old Mar 10, 2006 | 04:23 PM
jdium's Avatar
Default Check Engine Light - Cat Converter
My girlfriends car had the check engine light come on. When the dealership ran the codes, it came back that the catalytic converter is plugged...exhast something. I don't know the exact code. Any suggestions on the best way to fix this? Aftermarket pipe? Will the check engine light stay on if we just remove the converter? Is there any problem with driving this as it is now? Thanks
Old Mar 10, 2006 | 05:57 PM
tcontesh's Avatar
Default Re: Check Engine Light - Cat Converter (jdium)
Your best bet is to get a new converter because if you remove it then you will not be able to pass state inspection. The inside of converters sometimes break apart which causes them to plugg up and that sounds like the problem that you are having. Just get a new one either from Honda or a local parts store.
Old Mar 10, 2006 | 06:01 PM
jdium's Avatar
No state inspection here, the great state of Oregon...
Could I just get a section of piping with flanges welded to it to replace it with? Will this mess with the O2 sensor or trip any other codes?
Old Mar 10, 2006 | 06:12 PM
tcontesh's Avatar
Default Re: (jdium)
If you dont have a state inspection and you are not an enviornmental freak, then go ahead and take it off and put piping in its place.
Old Mar 10, 2006 | 06:14 PM
tcontesh's Avatar
Default Re: (jdium)
OH Yeah and as far as I know you wont throw any codes, as long as the 02 sensor is plugged in.
Old Mar 10, 2006 | 06:21 PM
jdium's Avatar
Sweet. Just as an add on, any decent exhaust upgrades I could talk her into that would cover this also? Cost is a big factor. Thanks
Old Mar 10, 2006 | 06:44 PM
tcontesh's Avatar
Default Re: (jdium)
yeah that would be cool, you should look into an axle back exhaust upgrade.
pretty much your whole exhaust system stays the same except from your axle and back, they are anywhere from $100 and up depending on the company.
Old Mar 10, 2006 | 06:47 PM
SMSP's Avatar
If her car is 96+ it's OBDII and you will throw a code with a test pipe.
Old Mar 10, 2006 | 07:05 PM
tcontesh's Avatar
Default Re: Check Engine Light - Cat Converter (SMSP)
before my current setup I had no cat, I actually had just a downpipe and a resonator. I never once threw codes and my car was an obd2. I also know people with hollowed out converters, and no there is no check engine light.
the 02 sensor just has to be plugged in somewhere. no false info.
Old Mar 10, 2006 | 07:26 PM
jdium's Avatar
Any recommendations for a cheap axle back system?
Old Mar 10, 2006 | 07:36 PM
tcontesh's Avatar
Default Re: (jdium)
DC Sports makes a pretty nice axleback that sounds nice and deep and is fairly quiet. give it a search and see how the pricing is.
Old Mar 10, 2006 | 10:03 PM
Tzer's Avatar
Good luck in whatever you end up trying. I had that same code. I put on a magaflow cat (nothing was wrong with our cat after removal and inspecting it) It still threw code 67. I got a Denso 02 sensor. Still threw the code. I gave up and just drove with the light on. I read on another forum where someone did the same as I did but replaced both 02 Sensors and it never fixed the problem. I wish you the best of luck in getting this fixed.
Tzer
Old Dec 23, 2006 | 11:59 AM
PDiddy66's Avatar
Default Re: (Tzer)
I feel your pain mine pulls the same code for about a week then turns off then back on.... then off. It drives me crazy i have replaced everything once and am getting ready to do it again when i do my new exhaust set up. i have no clue what the problem is. good luck though with your repair hope yours works
fcardenas
Honda Civic (2001 - 2005)
Mar 16, 2018 12:56 PM
freddysEF
Feb 11, 2008 08:59 PM
everlasting1832
Feb 10, 2005 11:23 AM
nexus da9
Mar 2, 2004 03:36 PM
PolySquared
Jan 17, 2002 01:43 PM
