heat keeps blowing when the switch is off wont turn off
Old Mar 10, 2006 | 02:33 PM
Hockey27925's Avatar
Default heat keeps blowing when the switch is off wont turn off
when i start my 98 teg gsr, stock except for intake and vafc2, the car will be alright, but when i start to drive the heat comes on full blast i can switch it from hot to cold but it will not turn off. what can it be,
Old Mar 10, 2006 | 04:35 PM
blkb18's Avatar
Default Re: heat keeps blowing when the switch is off wont turn off (Hockey27925)
its either the switch or the blower resistor.
Old Mar 10, 2006 | 05:06 PM
Sam92Teg's Avatar
Default Re: heat keeps blowing when the switch is off wont turn off (blkb18)
switch or stuck heater valve
When the resister starts to go, you usually start to lose your fan speeds one at a time untill the highest setting is all you have left, least that has been my experience.
Old Mar 10, 2006 | 05:07 PM
teggy182's Avatar
is the fan actually blowing or is heat just coming out the vents?
Old Mar 11, 2006 | 10:44 AM
Default Re: heat keeps blowing when the switch is off wont turn off (teggy182)
not sure if the fan is blowing didnt have the hood popped, but the heat is blowing on full blast but i can still switch it from hot to cold just cant turn it off
Old Mar 12, 2006 | 06:27 AM
Old Mar 12, 2006 | 06:29 AM
blkb18's Avatar
if the fan is blowing and you have no control over the speed its usually the blower resistor.
Old Mar 12, 2006 | 06:54 AM
BolivianDc2's Avatar
do you have the recirculation button on or off?
Old Mar 12, 2006 | 11:28 AM
Default Re: heat keeps blowing when the switch is off wont turn off (BolivianDc2)
off
Old Mar 12, 2006 | 01:23 PM
tomithy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BolivianDc2 &raquo;</TD></TR><TR><TD CLASS="quote">do you have the recirculation button on or off?</TD></TR></TABLE>
Air will still blow out if you have the recirculation button off. Not full blast.. but see if anything comes out if you have recirculation on with the fan turned all the way off.
Old Mar 12, 2006 | 02:16 PM
Default Re: heat keeps blowing when the switch is off wont turn off (tomithy)
if it does still blow with the button on what does that mean
dropculture
Feb 5, 2008 02:10 PM
Mrob91GS
Nov 28, 2004 07:12 PM
wardstar
Aug 30, 2004 01:45 PM
