Koyo Radiator Leaking....
I have a fairly new Koyo radiator (purchased in May 05'). It has a leak at the bottom left near the hose. Only doesn't leak from the hose. It leaks from the radiatior itself, right where the base meets the side. I was wondering if anyone had Koyo radiator's number in case it's still under warranty. If not is there any way I can fix it? Any help is appreciated. Thanx in advance.
-Regi
-Regi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vegas36 »</TD></TR><TR><TD CLASS="quote">I have a fairly new Koyo radiator (purchased in May 05'). It has a leak at the bottom left near the hose. Only doesn't leak from the hose. It leaks from the radiatior itself, right where the base meets the side. I was wondering if anyone had Koyo radiator's number in case it's still under warranty. If not is there any way I can fix it? Any help is appreciated. Thanx in advance.
-Regi</TD></TR></TABLE>
I had a modified C&R rad, added a couple ports welded on for the turbo coolant. One of them had a pinhole leak, just a drip. Some aluminum bars-leak stuff fixed it (permamently to survive track time and a couple radiator flushes.)
http://www.barsproducts.com/
$5 might save you some trouble....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ »</TD></TR><TR><TD CLASS="quote">
I thought that you shouldn't use that?
worked for me. *shrug*
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ »</TD></TR><TR><TD CLASS="quote">Yea, but it clogs up your lines and passges, just like cholesterol.
When my R is 65 years old I'll get it checked out for high coolant pressure.
</TD></TR></TABLE>When my R is 65 years old I'll get it checked out for high coolant pressure.
Thanx for all the replies... I've heard those liquids you put in there can clog stuff up. I was wondering if there was anything I can put on the exterior part of radiator to stop the leak? Or if anyone has a contact number for Koyo Radiators?
lucasbkellner
10
Nov 15, 2004 04:13 PM
new car...
(stupid IRS peepz where is my refund!!)
