obd-1 stonger then obd-0
Old Mar 10, 2006 | 11:18 AM
si 1's Avatar
Default obd-1 stonger then obd-0
If i am converting my crx from obd0 to obd1 what injectors should i use i hear you can use obd0 injectors but are they weaker then obd1 and whats the difference between them besides the resistor pack that you use in obd0
Old Mar 10, 2006 | 02:10 PM
EF_LSVtec's Avatar
Default Re: obd-1 stonger then obd-0 (si 1)
no they're not...a 310cc obdo is still the same 310cc if obd1...
Old Mar 10, 2006 | 02:47 PM
gnar kill's Avatar
Default Re: obd-1 stonger then obd-0 (EF_LSVtec)
there is no performance from switching to obd 1 injectors the only difference is obd0 injectors are peak and hold and require the injecotr resistor bos while obd1 injectors are saturated and saturated injecotors do not require a resistor box
Old Mar 10, 2006 | 05:23 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: obd-1 stonger then obd-0 (gnar kill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gnar kill &raquo;</TD></TR><TR><TD CLASS="quote">there is no performance from switching to obd 1 injectors the only difference is obd0 injectors are peak and hold and require the injecotr resistor bos while obd1 injectors are saturated and saturated injecotors do not require a resistor box </TD></TR></TABLE>
Exactly! There is no "weak" injector, only different flow rates, ans different amounts of resistance. Most B and D honda/acura engines use 240cc injectors regardless of obd version.
br8crumb
Jun 1, 2014 10:00 AM
CRX44
Aug 31, 2009 11:13 PM
dropNdestroyEF
Sep 12, 2008 05:47 AM
atarigamer01
13
May 20, 2008 09:23 AM
hondacivic90zc
Mar 6, 2007 06:02 PM
