K20a in a 98 Accord?
HASport has done a K24 swap out of the TSX with the 6 speed transmission, the mounts may be similar to the K20. I would think the 2.4 would be a better choice for our heavier accords.....
Back on subject, I'd contact HASport and make sure...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai »</TD></TR><TR><TD CLASS="quote">2.0L is a little small for a 3000lb car</TD></TR></TABLE>
Not to get too off this topic, if 2 liters is a bit small for a 3000lb car, why is the F20B getting popular?
no one in their right mind would put a F20 in a 6th gen. Most go FI on current motor or H22a/23 swap. F20 is fine for a 3/4th gen car but even those guys go H22a route if they can
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MestizoRacer310 »</TD></TR><TR><TD CLASS="quote">
Not to get too off this topic, if 2 liters is a bit small for a 3000lb car, why is the F20B getting popular?</TD></TR></TABLE>
do you even know why honda make the f20 in the first place? it's basically from h22
torque is a must if you have a fast **** accord
Man if I had a k series engine laying around I'd put it in.I have two 4gens but still.
K series engines are cool.I'm sure if you have torque problems you could just boost the k20.
or you could just sell the k20a you have access to and put the money into buying a k24
jsut to comment, ive seen a 89-90 civic hatch around my local car club meets that had a k20 in it, so if they can put one in there, im sure you could fit one into a 6th gen.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msedacca »</TD></TR><TR><TD CLASS="quote">jsut to comment, ive seen a 89-90 civic hatch around my local car club meets that had a k20 in it, so if they can put one in there, im sure you could fit one into a 6th gen.</TD></TR></TABLE>
You can make anything fit...but as mentioned your making a 2.0L pull a 3000 lb car as mentioned. Even the stock 6th gens came with 2.3L 4 bangers.
thevtecnician
Jan 6, 2004 06:23 AM
