state referee tech related... i'm in dire need of help from everybody experienced.
Old Mar 10, 2006 | 08:09 AM
the soL that could's Avatar
Default state referee tech related... i'm in dire need of help from everybody experienced.
I’m in desperate need of some expertise.
I have a JDM D15B. this vehicle needs to be brought to the state referee. A couple of questions. Will it pass? This is bone freaking stock by the way. Running off a P08 ECU.
What consists of a state referee examination?
The vehicle is a 94 del sol. If it will not pass that examine, how will I pass?
so far... this is what i have to get.
-Civic VX ECU (P07)
-VX O2 sensor
not sure what this means?
If the vehicle is a California certified vehicle then the engine must also be a California certified engine.
pep boys "gaurantee smog passing" stuff
Modified by the soL that could at 11:31 AM 3/10/2006
Old Mar 10, 2006 | 09:59 AM
Default Re: state referee tech related... i'm in dire need of help from everybody experienced. (the soL that
sometime in the near future. lol
Old Mar 10, 2006 | 10:07 AM
medside's Avatar
what i understand is everything connected to the exhaust has to be state legal, such as headers, downpipe, etc. also with the intake. and you have to be running off of a usdm ecu.
I think that is all you need to pass a jdm engine. please correct me if i'm wrong.
Thanks
Old Mar 10, 2006 | 10:14 AM
i've search... read almost all the 8978932 threads under referee, smog, and d15b. i'm not worried about the smogging portion of the examination because everything in my car is stock. **** i don't even have an intake. LoL.
what i'm concerned about is the visual.
they'll run the block code and it's going to be listed as a JDM 92-95 civic VTi engine. the car is a 94 so it should pass (passenger to passenger). that's about all they do correct?
Old Mar 10, 2006 | 11:02 AM
ZipTieGUy's Avatar
the block gotta come out a car thats newer than yours
Old Mar 10, 2006 | 11:06 AM
Default Re: (ZipTieGuy)
that car is a 94. didn't that engine run though 92-95
Old Mar 10, 2006 | 11:22 AM
Luserkid's Avatar
Default Re: (the soL that could)
Check the head stamp for the year of the car. If its 94/95 then youll be ok. If not then you might run into some problems depending on the ref.
Is it the D15B VTEC? I think you need to run a p28 and all smog equipment to that (4wire o2, evap crap, etc.)
Old Mar 10, 2006 | 11:37 AM
somebody posted a vx ecu (p07) and a 1 wire o2 will do me good. for the smog portion.
Old Mar 10, 2006 | 11:40 AM
vtakvtrak's Avatar
give the state referee guy 3 bills , he'll pass u fo sho
Old Mar 10, 2006 | 12:07 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the soL that could &raquo;</TD></TR><TR><TD CLASS="quote">somebody posted a vx ecu (p07) and a 1 wire o2 will do me good. for the smog portion.</TD></TR></TABLE>
The VX ECU is not the correct ECU for that motor, so it should not be the "accepted" choice. You need to run the P08. Besides, 95% of VX's use 5 wires. Good luck wiring that crap up AND the EGR to keep it from throwing a CEL.
Old Mar 10, 2006 | 12:23 PM
Default Re: (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">
The VX ECU is not the correct ECU for that motor, so it should not be the "accepted" choice. You need to run the P08. Besides, 95% of VX's use 5 wires. Good luck wiring that crap up AND the EGR to keep it from throwing a CEL. </TD></TR></TABLE>
i thought the VX ecu is a 1 wire (heater only) o2 sensor
Old Mar 10, 2006 | 12:30 PM
Hybrid96EK's Avatar
i thought the VX ecu is a 1 wire (heater only) o2 sensor</TD></TR></TABLE>
95% of them are 5 wires... They also have 4 wires. The only one wire I know of is the early HF and I THINK the CX. Even if it was a 1 wire, like I said.. you going to also hookup all the EGR control crap to keep it from tossing an EGR code? Trust me, its not the right ECU to use for that engine.
Old Mar 10, 2006 | 12:32 PM
95% of them are 5 wires... They also have 4 wires. The only one wire I know of is the early HF and I THINK the CX. Even if it was a 1 wire, like I said.. you going to also hookup all the EGR control crap to keep it from tossing an EGR code? Trust me, its not the right ECU to use for that engine.</TD></TR></TABLE>
don't think that p08 of mine will pass, since it's not USDM
Old Mar 10, 2006 | 12:49 PM
Hybrid96EK's Avatar
don't think that p08 of mine will pass, since it's not USDM</TD></TR></TABLE>
I didn't want to mention anything because I am sure people will climb down my throat... but, technically that engine shouldn't pass either since it has no US counterpart either.
Old Mar 10, 2006 | 01:14 PM
I didn't want to mention anything because I am sure people will climb down my throat... but, technically that engine shouldn't pass either since it has no US counterpart either.</TD></TR></TABLE>
i always thought it was the 92-95 VX? i know that this is also an issue.
Old Mar 10, 2006 | 04:40 PM
Hybrid96EK's Avatar
i always thought it was the 92-95 VX? i know that this is also an issue.</TD></TR></TABLE>
Well, maybe that is the equivilant they are using... The VX was a 1.5l and was a Vtec engine, so maybe that is how they classify it. Does the JDM D15B have the EGR though?
Old Mar 10, 2006 | 05:16 PM
schardbody's Avatar
the jdm d15b vtec needs a p28 and 4wire o2 in order to pass. make sure you have plenty of grime on the motor, a clean motor will add suspition.
Old Mar 10, 2006 | 06:07 PM
Sketch_hs's Avatar
Default Re: (vtakvtrak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtakvtrak &raquo;</TD></TR><TR><TD CLASS="quote">give the state referee guy 3 bills , he'll pass u fo sho</TD></TR></TABLE>
always works
Old Mar 22, 2006 | 11:43 AM
Layziejoe775's Avatar
Default Re: (Sketch_hs)
where do you guys recomend to a state referee in southern cali?....i heard goldenwest college have one and rio honda community college...correct me if i'm wrong.....also.....you do need a cat right?
Jul 30, 2006 09:09 PM
shbrown
Oct 10, 2005 03:06 PM
nxstrikerxn
Jul 29, 2005 01:39 AM
theFORUMman
15
Nov 8, 2004 03:47 PM
chris408
13
Mar 14, 2003 01:13 AM
