Upgrading My rotors and pads
Old Mar 9, 2006 | 07:07 PM
wicked95's Avatar
Default Upgrading My rotors and pads
Well I have a 5th gen accord ex 4cyc. Well i have had my oem rotors warped twice in the pass 2 years. So am looking for something that would give me better stopping power and wont warp like my oem rotors. Thanks
Old Mar 9, 2006 | 07:14 PM
P_Adams's Avatar
Default Re: Upgrading My rotors and pads (wicked95)
Brembo Rotors (Oem Blanks) (Standard)
Ceramic Brake Pads (stay away from semi-metalics)
I've run Brembo slotted Rotors without problems for two years. Avoid cross-drilled rotors (have a tendency to crack (Competition only)
P
Old Mar 9, 2006 | 07:20 PM
BLKFLSH's Avatar
Default Re: Upgrading My rotors and pads (P_Adams)
P, who makes Honda motor oil?
Old Mar 9, 2006 | 07:34 PM
BLKFLSH's Avatar
I saw the movie. Turned it off, cause I couldn't understand them. I had no idea they were talking about oil. Dam! Maybe I'll catch it on reruns. Thanks P.
Old Mar 9, 2006 | 07:41 PM
P_Adams's Avatar
Default Re: Upgrading My rotors and pads (BLKFLSH)
I truthfully can't tell you (but I'll try to find out for you)
I did have it on good authority the the crude which is used to manufacture Honda Lubricants actually comes form fossilized remains of Godzilla's distant cousins. Rumor has it that the refinery crew speaks perfect English, but there's this lag between the time their mouths move and when you hear it.
P
My God, you knew what I was going to say, before I said it! You're amazing; Man!
Old Mar 9, 2006 | 07:57 PM
BLKFLSH's Avatar
????????? I guess it's time to go to bed. I'm starting to hallucinate.
Old Mar 10, 2006 | 01:01 AM
iam7head's Avatar
Default Re: Upgrading My rotors and pads (Group A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Group A &raquo;</TD></TR><TR><TD CLASS="quote">
whats wrong with semi-metalics?</TD></TR></TABLE>
most of them will get make grooves as the pad wears down, they make noise, harder on rotor and their "bite" is very sensitive with temp.
i can't generalize everything because i can't tell you how exactly one brand will react compare to another band.
most pad maker have a less-headache chart to show comparison between their different line of pad.
for example:
organic street VS. ceramic VS. Metal
read and interpret all the spec before you pick the pad, for example, brake fade would be pority one if you doing track vs. organic street pad for oem replacement
pbr or axxis have a somewhat useful chart, also look up hawks
Old Mar 10, 2006 | 03:50 PM
syvlvr's Avatar
Hey P, did your Brembos get slotted by third party or by Brembo?
Old Mar 10, 2006 | 08:40 PM
P_Adams's Avatar
Default Re: Upgrading My rotors and pads (syvlvr)
Brembo. Bought them thru the Tire Rack
Gold Cadmium Plated / Slotted
I was looking at cross-drilled, but Brembo's attitude towards them confirmed what I knew (no warranty for cracking). They offer all three types (Blank, Slotted and Cross-drilled) but will only offer a warranty on the Blanks and the Slotted versions.
P
VBPType-S
Jun 2, 2007 05:55 AM
97civicsedan
May 12, 2005 11:10 AM
the DA in HONDA
Apr 27, 2004 09:15 PM
Abshonda
Mar 23, 2004 05:15 PM
Alexander
Oct 5, 2002 12:25 PM
