REDLINING AT 5500 rpm!!!
Old Mar 9, 2006 | 07:05 PM
CALC!_JUST_du_IT!'s Avatar
Default REDLINING AT 5500 rpm!!!
I had a buddy install a clutch kit for me a few weeks ago. He's a mechanic, so i thought he'd be familiar with the job, but the motor's been acting up since he gave it back to me. It happens randomly... i reach 5500 rpm, when vtec is supposed to kick in, and the motor behaves exactly as it does at the redline. If i turn the car off and on again, the problem stops, but eventually comes back. I don't know if the clutch install had anything to do with this, so i don't want to point any fingers, but i do want to know what's going on with my car. Please post a solution if you have one. PLEASE!!!
Old Mar 10, 2006 | 07:42 AM
Default Re: REDLINING AT 5500 rpm!!! (CALC!_JUST_du_IT!)
Any suggestions??? I'm i even ok to keep driving the car?
Old Mar 10, 2006 | 07:51 AM
drdisco69's Avatar
Check for loose wires and grounds. There's a ground wire for the ecu on the top of the thermostat housing, not uncommon to be left loose, and can cause erratic behavior.
Old Mar 10, 2006 | 07:56 AM
Default Re: REDLINING AT 5500 rpm!!! (drdisco69)
yeah, i quickly checked for any loose wires or harnesses. i didn't see anything, but i'll check more thouroughly. thanks. any other suggestions out there?
Old Mar 11, 2006 | 08:50 AM
sanimalp's Avatar
$cat /dev/urandom
is the car warmed up? cold rev limit is a little higher than 5500, but if it isnt warmed up it may cut earlier than you expect. just an idea.
OH_1fstgsr
28
Aug 11, 2010 06:09 PM
Jimster480
30
Mar 10, 2010 11:15 AM
Devious951
13
Jun 12, 2007 06:10 PM
aphex23
35
Jun 15, 2004 09:41 AM
takeheed
Sep 22, 2002 12:28 PM
