Which Tire, and Which Size: Azenis RT-615 vs. Toyo T1-R
Old Mar 9, 2006 | 06:22 PM
92integraVTECgsr's Avatar
Default Which Tire, and Which Size: Azenis RT-615 vs. Toyo T1-R
Buying new tires. Either Falken Aznenis RT-615 or Toyo T1-R. I am looking at either 205/50-15 or 195/50-15.
I have Rota Slips 15x6.5 rims with an offset of 40. I know I wont have any rubbing issues with that.
But I may sell the Rotas and buy some Stock 96 GSR wheels (not blades). They have an offset of 45. Now would 205/50-15's rub on those rims? I have a 92 Integra GS-R.
How are the Falken's in rain? I want something that is good in rain. I know the Toyo's should be pretty good in rain, but they are $50 more than the Azenis. Just wanted to know how the Azenis perform in rain.
Old Mar 9, 2006 | 06:46 PM
old man neri's Avatar
Default Re: Which Tire, and Which Size: Azenis RT-615 vs. Toyo T1-R (92integraVTECgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr &raquo;</TD></TR><TR><TD CLASS="quote">Buying new tires. Either Falken Aznenis RT-615 or Toyo T1-R. I am looking at either 205/50-15 or 195/50-15.
Stock is 195/60-14*. The 205s will work better. It should also a perfect size for 6.5" rims, not stretched or bulged.
*edited
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
From what I remember reading around here the RT-615 is not the best in the rain. The Goodyear F1 GS-D3 is much better. Hope fully someone else can fill in the blanks for the pros and cons of each tire (*cough* *cough* ....Ken?)
More reponses should come in tomorrow,
Cheers.
Modified by old man neri at 2:26 AM 3/10/2006
Old Mar 9, 2006 | 07:13 PM
Default Re: Which Tire, and Which Size: Azenis RT-615 vs. Toyo T1-R (old man neri)
ya i want the 205's.. They are a little wider and offer more grip.
I ya I might go the Goodyear route.. I want something great in both rain and dry.
Old Mar 9, 2006 | 07:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr &raquo;</TD></TR><TR><TD CLASS="quote">ya i want the 205's.. They are a little wider and offer more grip.
don't confuse wider with better grip, especially in the rain. Just wait till tomorrow for more opinions before you make a decision.
Old Mar 9, 2006 | 07:33 PM
ya i know narrow equalls better grip in the wet and snow (im from ontario to ) because it can cut through better..
205/50 just seems to be the most popular size.
Old Mar 9, 2006 | 07:35 PM
FULL throTTLe's Avatar
if ur car isn't that low, 205 would be good
Old Mar 9, 2006 | 07:36 PM
Default Re: (FULL throTTLe)
ya it's only on prokits. I just want something that is good in rain and dry.
How are the azenis in the rain? anyone?
Old Mar 9, 2006 | 08:27 PM
Default Re: (92integraVTECgsr)
Sorry, a bit more looking: more good choices are; Kumho Ecsta SPT, the Yokohama AVS ES100, or Dunlop Direzza DZ101. All should have good wet traction. I really don't know too much about rubber though. Hopefully the guru of vulcanization (nsxtasy) will be on here in the morning and sort you out.
Cheers.
p.s. why the other post?
https://honda-tech.com/zerothread?id=1554381
Old Mar 9, 2006 | 10:04 PM
nsxtasy's Avatar
H-T Order of Merit
Your '92 GS-R came with 195/60-14 tires stock. 205/50-15 is your best bet for size, even better than the 195/55-15 which is best for the '94 and later GS-R. The 195/50-15 size you mentioned is too small for your car.
The Azenis RT-615 is the stickiest street tire around. So if you care ONLY about dry traction, that's the tire to get. However, if you care about wet traction, there are lots better tires around (even though the RT-615 isn't as bad as its RT-215 predecessor, most other tires are just better at this). Also, the RT-615 wears extremely rapidly, so you might go through 2-3 sets in the same number of miles that a single set of other tires lasts.
The Goodyear that old man neri mentioned doesn't come in 205/50-15.
The three budget performance tires that old man neri mentioned are all very good on dry pavement, and outstanding in rain. They are very similar to each other in performance, but very different in price for 205/50-15. The Dunlop Direzza DZ101 is $45 at Edge Racing, and the Tire Rack currently has a $50 rebate on a set of four that makes their price almost exactly the same. The Kumho Ecsta SPT is $61, and the Yokohama ES100 is $75. These are all very good tires, although not at Azenis levels of dry traction, and the Dunlop is an incredible bargain.
If you're looking for a step up in performance from those three tires, you can get a bit more performance by spending more money, either for the Kumho Ecsta MX ($80) or the Toyo T1-R ($90).
Old Mar 9, 2006 | 10:38 PM
Default Re: Which Tire, and Which Size: Azenis RT-615 vs. Toyo T1-R (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">Your '92 GS-R came with 195/60-14 tires stock. </TD></TR></TABLE>
and...........editied. I don't know how that one got by me. Of course it's not like it's the first time.
The eagle F1 does come in 195/50-15. It's doable although not the best size. I have no idea if the size differential is worth advantage if any. Again, I really know nothing about rubber.
Cheers.
Old Mar 10, 2006 | 08:05 AM
Type X's Avatar
sorry to threadjack for a sec
are 615's good enough to get 1 full spring to fall out of
( roughly )
i do pretty much 1500 a month in highway, street miles with VERY rare track runs
Thanks
- mike
Old Mar 10, 2006 | 08:58 AM
alwaysoverkill's Avatar
Default Re: Which Tire, and Which Size: Azenis RT-615 vs. Toyo T1-R (Type X)
Just wanted to add 195/50/15 or 205/50/15...while if you go Azenis you don't have a choice, they only have 205/50/15 available in 15" as of now.
I've had Toyo Proxes 4, Hankook Z212 and now i'll be mounting Azenis RT-615 is about 2 weeks. Tire wear is a concern with super sticky tires like Azenis, however if maximum dry grip is what your after then thats your tire. If you want good grip and a tire that will last longer then 12,000MI, then you may want to look into other tires. Also if you want something good in the rain, you want a tire like NSXatcy stated, Goodyear or such. RT-615 will get by in the rain, but speaking from experience with the Hankook Z212 you do not want to be pushing these types of tires in the rain. 1 - they are meant for max dry traction and 2 - they often just don't have the channels a good rain tire does to channel the water away.
Sounds like to me, you want to avoid the RT-615 and look into others
Old Mar 10, 2006 | 11:40 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Which Tire, and Which Size: Azenis RT-615 vs. Toyo T1-R (alwaysoverkill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type X &raquo;</TD></TR><TR><TD CLASS="quote">are 615's good enough to get 1 full spring to fall out of
( roughly )
i do pretty much 1500 a month in highway, street miles with VERY rare track runs</TD></TR></TABLE>
You should be able to count on 10K miles out of a set of the RT-615. At 1500 miles a month, that's about seven months. You might get more (or less), of course. For maximum treadlife, check the pressure at least once a month, and rotate the tires to even out the wear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alwaysoverkill &raquo;</TD></TR><TR><TD CLASS="quote">Just wanted to add 195/50/15 or 205/50/15...</TD></TR></TABLE>
195/55-15 or 205/50-15 are fine, and there are plenty of tires available in both those sizes. 195/50-15 is really too small for a GS-R; you can fit them on the car, but there's absolutely no reason to do so.
Old Mar 10, 2006 | 01:00 PM
I meant 205/50/15 is the Azeni 15" so it narrows the choice down, since 195 is not available
Old Mar 10, 2006 | 10:18 PM
track_assassin's Avatar
i dont know but i live in florida and when its rain season, it really rains. i've ran azenis in rain and it does me good. just avoid puddles
Old Mar 11, 2006 | 07:34 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (track_assassin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by track_assassin &raquo;</TD></TR><TR><TD CLASS="quote">i dont know but i live in florida and when its rain season, it really rains. i've ran azenis in rain and it does me good. just avoid puddles </TD></TR></TABLE>
You can drive in rain with any tires. But some tires are better than others. And almost all other tires are better than the new Azenis (which are still better than the old Azenis). They're not exactly bad, but most other tires are better.
If you don't care how good your tires are in the rain, then get the Azenis. If you're looking for a tire that does pretty well in the rain - meaning, better than many other tires - then the Azenis is not a good choice.
twentyhurtz
Nov 25, 2008 05:02 AM
actek23
Jan 8, 2008 05:48 PM
<StevieG>
Honda Civic (2001 - 2005)
12
Apr 2, 2007 07:00 PM
ITR Factor
Dec 18, 2003 09:55 AM
jonsteR
Dec 12, 2001 01:46 PM
