215 size tire??
i have a set of 14" wheels and i need tires so i was lookin at either 205/60R-14 or 215/60R-14. I wanted to know if i would rub with the 215's? I'm dropped on Neuspeed sports. i don't have a pic right now though. does anyone have 215's with a drop or should i not even try it and just go with the 205's? It's on an integra by the way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMD »</TD></TR><TR><TD CLASS="quote"> It's on an integra by the way.
Is this for the 2000 GS integra in your sig?
If so: 205/60-14 is the better of the two. 215s would have a diameter that is 3% bigger and 20mm wider than stock. That's usually on the threshold of rubbing and who knows if it is dropped. 205s are only 1% bigger in diameter and only 10mm wider than stock.
Lan
Apr 27, 2006 06:46 PM
