Code 13 HELP
Old Mar 9, 2006 | 05:15 PM
$racer1's Avatar
Default Code 13 HELP
mY 91 hatchback is trowing out the Baric metric pressure code. Its has the stock engine. Anyone knows what that problem is????
Old Mar 9, 2006 | 05:17 PM
RCautoworks's Avatar
Default Re: Code 13 HELP ($racer1)
Code 13 - Atmosphric Pressure Sensor
The PA sensor should read close to the MAP sensor of 2.75v, this may very small amounts due to current weather conditions and elevation. Due to it's location, it is probably easier to check the voltage at the ECU. This sensor vary seldom, or never at all should fail. Flooding may have damaged it, at one time or another.
Old Mar 17, 2006 | 12:19 PM
$racer1's Avatar
Default Re: Code 13 HELP (90blackcrx)
You think it could be cause my fuel pump, cause i have a 1.8 ls pump and my engine is a 1.5
Old Mar 17, 2006 | 04:08 PM
Nope not at all
DA_zooooms
Aug 10, 2009 09:08 PM
d_boi_swag
Jul 5, 2009 12:14 PM
ILLICON3000
Aug 4, 2004 03:25 PM
.brad
Feb 26, 2002 03:30 AM
