HELP Horn Doesnt Work (Installed my MOMO wheel)
Old Mar 9, 2006 | 04:37 PM
Mistermark's Avatar
Default HELP Horn Doesnt Work (Installed my MOMO wheel)
well i finally installed it and everything was going great,
the horn button doesnt work.
i followed the howto found on honda-tech
the wire from the SRS connector all the way upto the (+) button has 12.3 volts (which is good) and the ground is fine too, why doesnt the horn work? if i have power and yes, i did check the fuses too.
what should i check next?
Old Mar 9, 2006 | 04:57 PM
tha_badguy's Avatar
who cares
u should b more worried about not havin an airbag
my horn works but do i use it
Thats a Negative
Old Mar 9, 2006 | 04:58 PM
Mistermark's Avatar
i care, about the horn
Old Mar 9, 2006 | 05:13 PM
usdmEHboy's Avatar
Default Re: (tha_badguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tha_badguy &raquo;</TD></TR><TR><TD CLASS="quote">who cares
Thats a Negative</TD></TR></TABLE>
you my friend..are a moron.
Old Mar 9, 2006 | 05:16 PM
5lugSlug's Avatar
if you have a horn maybe you wont need to use the airbag by getting the divers attention back on the road
but back to subject, i didnt know the SRS wires had anything to do with the horn?
Old Mar 9, 2006 | 05:17 PM
Mistermark's Avatar
lol k, can we get back to my question please.
Old Mar 9, 2006 | 05:34 PM
Mistermark's Avatar
at the SRS connector (where the Horn power comes from) could i jump that terminal to a temporary ground just to see if the horn goes off? if it doesnt what else should i check?
Old Mar 9, 2006 | 05:46 PM
Syndacate's Avatar
Default Re: (EK-tacy98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK-tacy98 &raquo;</TD></TR><TR><TD CLASS="quote">
but back to subject, i didnt know the SRS wires had anything to do with the horn?</TD></TR></TABLE>
They're in the same 3 way wiring harness (or is it 4 way?) -- Either way, it's part of the same harness
Old Mar 9, 2006 | 05:48 PM
Mistermark's Avatar
the SRS wire goes up the steering column to the SIR coil (cable reel) wtvr u wanna call it. and one of the connections from the SIR coil goes to the horn.
so in the write up (how to) it tells you to put a wire in the SRS connector (since the SIR coil is now out of the system) which is the prolly the horn power wire.
Old Mar 10, 2006 | 03:39 AM
Mistermark's Avatar
does any1 know where i can find a wiring diagram online
Old Mar 10, 2006 | 04:51 AM
djsire's Avatar
Default Re: (Mistermark)
my air bag is disconnected and i still ahave a horn so i would have to say you are wrong on that my friend. thats why its not workin
Old Mar 20, 2006 | 10:51 AM
integraXTC's Avatar
Default Re: (djsire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsire &raquo;</TD></TR><TR><TD CLASS="quote">my air bag is disconnected and i still ahave a horn so i would have to say you are wrong on that my friend. thats why its not workin</TD></TR></TABLE>
the horn is in that cable reel w/ the srs. So you don't know ****.
delsoldrew
Jun 19, 2007 12:37 PM
jdm_gal25
Apr 14, 2007 09:00 AM
maxxborist
Nov 6, 2006 08:57 AM
BlueIntegraBoy
Oct 20, 2006 05:38 PM
Babakarab
Jun 13, 2006 05:01 PM
