OBD to OBD1 distributor wiring. SEARCHED!
Old Mar 9, 2006 | 04:07 PM
hmtcrxsir's Avatar
Default OBD to OBD1 distributor wiring. SEARCHED!
I wanted to know if i were to swap a D16z6 in my CRX HF. Using the distributor from the z6 OBD1 and the engine harness from the HF. How can i convert it so that the HF harness can use the OBD1 distributor.
THanks in Advance
Old Mar 9, 2006 | 04:11 PM
APEX CRX's Avatar
Default Re: OBD to OBD1 distributor wiring. SEARCHED! (hmtcrxsir)
wires are a match color to color. but you'll need the OBD-1 dizz connectors
Old Mar 9, 2006 | 04:21 PM
hmtcrxsir's Avatar
Default Re: OBD to OBD1 distributor wiring. SEARCHED! (APEX CRX)
should i just cut the connectors off the HF harness and use the OBD1 distributor connectors. so its basically the same color?
Old Mar 9, 2006 | 05:33 PM
BlueCrxNC's Avatar
Just de-pin the OBD0 connector and put them in the OBD1 connector in the correct place. All the pins are the same or at least they fit and work.
Old Mar 9, 2006 | 06:30 PM
si0385.'s Avatar
Default Re: (BlueCrxNC)
either repin or you can order a conversion harness but i find it easier and a cleaner look if you repin because when you use the adapter harnessthere is an extra 4-6 inches of wire to hide
Old Mar 9, 2006 | 06:41 PM
ExplicitSpeed360's Avatar
Banned.
Default Re: (si0385.)
obd1 dizzy plug connectors and color to color on mine there was 2 white wires one was inside the loom other was outside the loom...
Old Mar 9, 2006 | 07:56 PM
mr. carpenter's Avatar
Default Re: (ExplicitSpeed360)
https://honda-tech.com/zerothread?id=1349052
Old Mar 9, 2006 | 08:27 PM
Rywire's Avatar
Default Re: (mr. carpenter)
some dizzys areent color to color.... the aftermarket ones are colored wrong...
Old Mar 9, 2006 | 11:30 PM
theinfamouskonrad's Avatar
Default Re: (droppedcrxsi)
Old Mar 12, 2006 | 11:07 AM
uglyrex's Avatar
Default Re: (theinfamouskonrad)
hope this helps?? it should definately open a can of worms the bottom is a si/hf harness
LOL
Modified by uglyrex at 6:05 PM 3/14/2006
Modified by uglyrex at 6:06 PM 3/14/2006
Modified by uglyrex at 6:07 PM 3/14/2006
Modified by uglyrex at 6:27 PM 3/14/2006
Old Mar 12, 2006 | 11:13 AM
gen2b20vtec's Avatar
Default Re: (uglyrex)
Just got to rywire.com buy his obd0 to obd1 distributor harness
h22aCb7
Aug 29, 2009 06:19 AM
ExplicitSpeed360
May 27, 2006 12:31 PM
4crx4me
Jan 31, 2004 07:36 PM
Ruby Civic
Dec 11, 2003 04:07 AM
Norcalstoppy
Jul 13, 2002 08:02 AM
