88 CRX DX-SI Cluster question
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civichbsi »</TD></TR><TR><TD CLASS="quote">as long as its another 88-89 cluster its the same</TD></TR></TABLE>
I'm not sure it is plug and play. I have an89 Si and the cluster has the seat belt warning light between the temp and fuel gauge. I took another 89Si gauge that didn't have the seat belt light there and is a working cluster, the gas and temp gauges would not work. why are you changing clusters anyway?
The are 2 idfferent manufacures of clusters, each with different wiring in 88-89. Some are stamped NS, others are made by ND.....make sure to use the same one your car is already using.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz »</TD></TR><TR><TD CLASS="quote">The are 2 idfferent manufacures of clusters, each with different wiring in 88-89. Some are stamped NS, others are made by ND.....make sure to use the same one your car is already using.</TD></TR></TABLE>
that is correct, btw, where are these stamps?
Deetz, thank you for confirming what I always thought about the wiring. It is different! Tthe plug and play works when you replace with the same type cluster as I found out the hard way- $$ wasted on wrong clusters thinking they would work.
civictyper96
14
Apr 14, 2010 02:56 PM
efnick
Oct 1, 2007 01:48 PM
