Just got Falken Azenis...
Old Mar 31, 2002 | 03:35 PM
comptechgsr2000
Guest
Posts: n/a
Default Just got Falken Azenis...
Are these tires softer than stock Type R tires? What does 200 thread wear mean?
By the way the performance is great compared to stock GSR tires.
Old Mar 31, 2002 | 03:41 PM
mafay2's Avatar
New User
Default Re: Just got Falken Azenis... (comptechgsr2000)
Where did you get it from?
Old Mar 31, 2002 | 03:43 PM
mojoGSR92's Avatar
Treadwear ratings only apply for one company against that same company. Say you have Falken Ziex vs. Falken Azenis then you can compare them. But if you are trying to compare those to the stock RE's based on treadwear you will not get a fair comparison based on the 200 number alone.
The only way to really test one compound as being softer than another is to use a durometer under controlled conditions (i.e. same place on tire, same weather conditions, same amount of use on each tire). A durometer gives you a relative number which can tell you that one compound is softer than another, is softer than another, so on and so forth.
Old Mar 31, 2002 | 03:46 PM
Bob#455's Avatar
I think <u>every</u> Type R owner that is running 205/50/15 Falken Azenis has said that they have stiffer sidewalls and grip better than the stock 195/55/15 Bridgestone RE010s.
Old Mar 31, 2002 | 04:23 PM
haloseven's Avatar
Default Re: Just got Falken Azenis... (mafay2)
vulcan tire is selling them, instock and only $63/ea
Old Mar 31, 2002 | 04:25 PM
GokuSSJ4's Avatar
Default Re: Just got Falken Azenis... (haloseven)
200 threat wear , not bad at all .
my pirellis have 160.
Old Mar 31, 2002 | 04:28 PM
quikrpm'z's Avatar
OT. whose still waiting for their order from discount?
Old Mar 31, 2002 | 04:40 PM
GRM Scott's Avatar
25 Year Member
Default Re: Just got Falken Azenis... (Spoon1)
As mentioned, treadwear is tottally irrelvant between manufacturers, and probably pretty useless even within a manufacturer. My 160 treadwear pirellis are a LOT harder than my 200 treadwear azenis...and the azenis are rated that way partly for ST legality in solo 2 methinks...
Old Mar 31, 2002 | 04:50 PM
comptechgsr2000
Guest
Posts: n/a
Default Re: Just got Falken Azenis... (Aleph)
I wanted to know about how many miles these tires last with normal driving.
Old Mar 31, 2002 | 05:12 PM
Suprdave's Avatar
Default Re: Just got Falken Azenis... (quikrpm)
Me....
Suprdave
Old Mar 31, 2002 | 05:14 PM
nekkedR's Avatar
whats normal driving in a type r???
Old Mar 31, 2002 | 07:46 PM
nsxtcjr's Avatar
New User
Given that the RE010 varies by a factor of 3 to 4 (some owners get less than 7K miles while others last well over 20K miles), I would bet the same thing is true with the Azenis. Depends on how you use them.
Old Mar 31, 2002 | 07:50 PM
387's Avatar
387
Default Re: Just got Falken Azenis... (nsxtcjr)
I am tired of waiting for these FAWKING AZNIS. I am going to find something else.
Old Mar 31, 2002 | 07:51 PM
Renegade's Avatar
I got mine put on on sat morning.
Old Mar 31, 2002 | 09:07 PM
comptechgsr2000
Guest
Posts: n/a
I never knew RE010 could last 20000 miles. Thanks NSXCJR
reysi1026
Oct 19, 2010 03:36 AM
Tad
60
Aug 22, 2003 11:52 AM
typeR 507
Apr 18, 2003 01:38 PM
NightHawkC5
Feb 22, 2003 01:59 PM
XpodX
Aug 23, 2002 08:47 AM
