96-97 JDM ITR 4 lug conversion...cant find it in search
Old Mar 9, 2006 | 09:58 AM
Jaydem02's Avatar
Default Question: 96-97 JDM ITR 4 lug COnversion...cant find it in search
I was wondering if anyone knows....if the "REAR" caliper assembly and arm assembly is the same for example on a GSR as the JDM 4 lug rears (I know the bolt pattern is different...but is the bolt pattern the only difference in them)
The reason I ask is b/c I recently received my ITR 4 lug conversion, and the guy sent me (2) rear "RIGHT" sides and so now I need to find a "LEFT" rear side assembly and wanted to swap out the 4 by 100 to 4 114
so my question is the only difference between GSR rear disc and JDM ITR 4 Lug disc the bolt pattern and can they be interchanged??
thanks
Old Mar 9, 2006 | 02:21 PM
SlammedDC2teg's Avatar
Default Re: Question: 96-97 JDM ITR 4 lug COnversion...cant find it in search (Jaydem02)
Im pretty sure its the same, besides the lug pattern and size of brake rotor.
Old Mar 9, 2006 | 02:34 PM
cltitus's Avatar
if im correct the 96 spec dm is a 4x114.3 and the 97 is 5 x 114.3 corect me if im wrong
Old Mar 9, 2006 | 02:36 PM
YumVTEC's Avatar
Default Re: (cltitus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cltitus &raquo;</TD></TR><TR><TD CLASS="quote">if im correct the 96 spec dm is a 4x114.3 and the 97 is 5 x 114.3 corect me if im wrong</TD></TR></TABLE>
96-97 JDM ITR = 4x114.3
98+ JDM ITR = 5x114.3
97+ USDM ITR = 5x114.3
back on topic though, does anyone know if the rear spindles are different between 96 spec JDM and 98 spec JDM? i know USDM ITR has a longer spindle in the rear than the other integra models.
Old Mar 9, 2006 | 07:26 PM
Jaydem02's Avatar
so are they the same?
Jay
Old Mar 9, 2006 | 08:36 PM
DB8ITR's Avatar
Default Re: (YumVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaydem02 &raquo;</TD></TR><TR><TD CLASS="quote">so my question is the only difference between GSR rear disc and JDM ITR 4 Lug disc the bolt pattern and can they be interchanged??
Well your question doesn't make much sense because you kinda answered it yourself. They can't be interchanged because of the different bolt pattern. I do believe the calipers are the same as a GSR.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YumVTEC &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know if the rear spindles are different between 96 spec JDM and 98 spec JDM? i know USDM ITR has a longer spindle in the rear than the other integra models.</TD></TR></TABLE>
I am currently swapping my DB8 ITR 4 lug to the USDM 5, and can verify that the 96 spec rear spindle is the same as the USDM ITR. I would imagine the 98 spec would be the same.
Old Mar 10, 2006 | 05:03 AM
Circuit Star-29's Avatar
Default Re: (4DoorJDMITR)
Just press out the hubs of one of the rears. Try that...pretty sure its the same trailing arm..just a different hub.
Old Mar 10, 2006 | 08:48 AM
Jaydem02's Avatar
thanks Circuit Star-29..thats the answer I was looking for..
I know that the bolt pattern is different!
Old Mar 11, 2006 | 06:57 AM
Cvic90's Avatar
Default Re: (Jaydem02)
the GSR is the same as the itr 4x114.3. The Exception is the bolt pattern. the calipers and brackets are the same. if you redrill gsr rotors they will fit.
Modified by Cvic90 at 11:19 AM 3/15/2006
Old Mar 11, 2006 | 08:30 AM
Jaydem02's Avatar
is LS the same as GSR??? or even 99 civic si rears?
thanks
Old Mar 15, 2006 | 10:21 AM
Cvic90's Avatar
I've been told the ls and gsr use different pads. I haven't ever checked it out.
gursh d
Jan 20, 2008 03:40 PM
polything
Sep 28, 2007 07:28 AM
gurlracer_camille
Aug 27, 2007 08:11 PM
dasickestda9
Aug 25, 2006 04:07 PM
..::91TEG-G2::..
Feb 25, 2004 07:57 PM
