thicker head gasket ??
Old Mar 9, 2006 | 09:52 AM
b18delturbo's Avatar
Default thicker head gasket ??
im doing an ls vtec conversion next week, it will be turbo. im wondering if a thicker head gasket would drop my compression and by how much with this setup.
also where can i find a thicker gasket, how much boost on stock internals, and would they be torque different?. any help would bee sweet
set up:
B16 soon LSV
t3/t4 turbo
RC 440's
crom chip p28
VAFC for fine tuning
Old Mar 9, 2006 | 11:25 AM
killerformula's Avatar
Generally adjusting compression by using different sizes of head gaskets is not the best decision. This is beacuse it changes your quench distance (the distance btw the top of the slug and the bottom of the head). Proper quench is used to create a cooling effect from the fuel on the chamber and piston. When quench is incorrect, you can have less compression and have more propensity to spark knock. From my experience building chevy motors quench distance is usually about .044" Find out what the proper distance is for this motor, and stick to it!
K
Old Mar 9, 2006 | 01:58 PM
integlspwr2k's Avatar
Default Re: thicker head gasket ?? (b18delturbo)
i'm running a .074" cometic HG on a B16. made 330whp @ 14psi. i say go for it.
Old Mar 9, 2006 | 02:23 PM
SVOboy's Avatar
Why would you tune your ecu and then "tune" again with a vafc. Tuned ecu = best, vafc is somewhere down near the bottom of goodness. Don't mess up a good tune with vafc,
Old Mar 9, 2006 | 03:45 PM
kaoss_11's Avatar
B A N N E D
Default Re: (SVOboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy &raquo;</TD></TR><TR><TD CLASS="quote">Why would you tune your ecu and then "tune" again with a vafc. Tuned ecu = best, vafc is somewhere down near the bottom of goodness. Don't mess up a good tune with vafc, </TD></TR></TABLE> This man speaks the truth!
Modified by kaoss_11 at 5:00 PM 3/9/2006
Old Mar 9, 2006 | 04:16 PM
spuddo01's Avatar
Default Re: (kaoss_11)
thicker HG = More BOOST HP and TQ.
go for it
Old Mar 10, 2006 | 10:34 AM
it was a blind tune was getting to much fuil washing out the piston ring and and thin out my oil, not a good tune. the vafc was used to -fuil gave me a better air/fuil.
so where can i pic up a thicker gasket?
Old Mar 10, 2006 | 10:42 AM
SVOboy's Avatar
Ah, good tunes are good,
Old Mar 10, 2006 | 10:53 AM
H.A.R.T B18C1EG6's Avatar
inline pro sells thicker headgaskets
they make pretty good power from their ls/vtec
Old Mar 10, 2006 | 04:56 PM
spuddo01's Avatar
Default Re: (H.A.R.T B18C1EG6)
cometic
Old Mar 13, 2006 | 09:25 AM
thanks for the help
Old Mar 13, 2006 | 09:51 AM
Turbo_y8's Avatar
Default Re: (b18delturbo)
ive got the cometic hp hg, love it, with arp head studs
Old Mar 13, 2006 | 09:53 AM
B16Drag's Avatar
cometic hg... check out some sponsors on here or nipponracing.com
arp head studs, go with the gsr ones.
Old Mar 13, 2006 | 10:28 AM
Archidictus's Avatar
Unceasing Measure
Default Re: (spuddo01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spuddo01 &raquo;</TD></TR><TR><TD CLASS="quote">thicker HG = More BOOST HP and TQ.
go for it </TD></TR></TABLE>
Incorrect. HP and torque are determined by the quality of the tune and the efficiency of the build. Turning up the boost will actually make less power on a 9.0 : 1 engine than on a 12.0 : 1 engine, it will simply be safer to do on a lower quality tune.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18delturbo &raquo;</TD></TR><TR><TD CLASS="quote">it was a blind tune was getting to much fuil washing out the piston ring and and thin out my oil, not a good tune. the vafc was used to -fuil gave me a better air/fuil.
so where can i pic up a thicker gasket?</TD></TR></TABLE>
Yeah, that says nothing for a VAFC's ability to tune jack ****. VAFC's are ricer toys, not proper tuning aparatus. If you have someone tune with Crome who knows wtf they're doing, you wont have that problem. Why the hell didn't you just retune the car with Crome - which is free - rather than buy a VAFC?
And it's "fuel" not "fuil"
People, the headgasket and the internals don't make nearly as much of a difference as an awesome tune will. If Mase or Church or Sgt. or St00pid tunes your car, you'll have a stock-block monster that will last forever with proper maintenence. Period. All the gadgets and parts in the world won't save an engine from a healthy dose of stupid.
Old Mar 16, 2006 | 09:53 AM
Default Re: (Archidictus)
back to the hole tuneing thin i moved to ny then turbo my car my boys in nc did my chipping he i told hi what it had and he tuned from there. don't know any one in NY that tunes or it would of been done a 3 week back. and about the hole rice thing not cool my boy wit his hatch in NC ran 10.2 in 1/4 at 14psi with 75 shot the only thing he had for tuning was a VAFC so rice or not they still kick ***. oh yea FUEL.
kevin7200
Dec 23, 2014 04:47 PM
t57b18
Sep 19, 2006 04:54 PM
silentdaredevil2
Nov 24, 2005 12:29 PM
BAZ
May 5, 2003 06:49 PM
