YS1 Transmission Removal
Old Mar 9, 2006 | 06:26 AM
CodyC142's Avatar
Default YS1 Transmission Removal
hey, this is my first tranny swap alone, usually my friend helps, I took out the shafts last night, starter, clutch cables, speedo, and unbolted the bellhousing.. my question is how many bolts hold it on? ive taken 6 out so far.. all 17 mm, any tips on actually dropping it to the floor?
this is on a 90 tegra ls
-thanks
Cody
Old Mar 9, 2006 | 06:41 AM
egturbolsvtec's Avatar
I just did my clutch last weekend and u have to remove the motormounts that are connected to the tranny , half shaft, there is 4 bolts u have to get from under the car one is located under the front mount the other is under the rear mount, there is also 2 bolts that go right to the rear mountthat go through the brtacket and into the tranny also a metal plate that protects the bottom of the flywheel there is 5 bolts holding that on,
Old Mar 9, 2006 | 06:43 AM
CodyC142's Avatar
Default Re: (amb16teg)
I know that there are 3 bolts underneath the car holding the tranny onto the motor.. and 3 more up top.. are there anymore than that? and i removed the mount by the strut tower.. do i also need to get the one by the radiator?
thanks again
Cody
It is not a hard job if u have any more qeustions let me know.
Old Mar 9, 2006 | 06:44 AM
Did u get the 2 bolts that go through the rear mount
Old Mar 9, 2006 | 06:45 AM
There is one right in front of rad
CodyC142's Avatar
no the only mount ive even messed with is the one by the strut tower
Old Mar 9, 2006 | 06:49 AM
u have to get the mount that is on the crossmember
averyvm
Aug 7, 2007 09:57 PM
Alpinestar03
May 11, 2007 04:26 PM
cincispeedemon
Oct 10, 2004 02:50 PM
h2point2
Apr 16, 2004 12:17 PM
jovial111
Dec 22, 2003 02:30 PM
