Cheap jdm power folding mirrors
Old Mar 8, 2006 | 11:50 PM
Solscud007's Avatar
Default Cheap jdm power folding mirrors
Ok for those you like the JDM power folding mirrors listen up. those who don;t then shut the hell up and go somewhere else.
Most people want the 98+ style mirrors. however the 98+ power folding mirrors are like 300 dollars. For what? jsut a molded piece of plastic.
SOOOOO for those who hacve 98+ USDM mirrors. you can swap out exteriors with the older mirrors that are half the price. Password sells 94-97 style mirrors for only 169 with switch and relay.
I have yet to truly test this idea as dont have 98+ mirrors at all. I took apart my JDM power folding mirrors as a test to swap out my stock housings so I dont have to get anythign painted. and realized that the outer piece that has that rectangular moulding could prolly be swapped out.
pop out the mirror. Be careful when popping it out
You will need to remove the screws and the housing will separate.
this is the part I think you can swap out for the 98+ mirrors if you got them
Old Mar 8, 2006 | 11:52 PM
gaydm.accord's Avatar
did this on several accords...
on accords the coupe and sedans base are different you can interchange them.
i dont know if the acura base's are different between the 4 door and 2 doors.
Old Mar 8, 2006 | 11:53 PM
Solscud007's Avatar
Default Re: (gaydm.accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gaydm.accord &raquo;</TD></TR><TR><TD CLASS="quote">did this on several accords...
i dont know if the acura base's are different betweent he 4 door and 2 doors. </TD></TR></TABLE>
which part did you do?
Old Mar 8, 2006 | 11:56 PM
not quite sure i understand the question...
i've swapped out the power folding mirrors ont he accords because i didnt want to spend the money on repainting mine personally... then my friend had a a set and i interchanged the bases with a coupe set just to test them out. and they work.
haven't done one on integra yet... but when i did it on the accord. theres a way to opt out of pulling th emirror out if its too difficult... get a long flat head screw driver and angle it in there and use the side at a 90 degree angle to take out all the screws.
Old Mar 9, 2006 | 03:33 AM
dc2nick's Avatar
I actually didn't know the 94-97 were different looking than the 98+
Old Mar 9, 2006 | 04:56 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Yes you can do this, keep in mind that to swap the triangular base pieces, you will have to de-pin the harness plug to get the harness through the hole in the base piece.
This is what I did when I bought 98+ mirrors for my car. The mirrors I received came off of a Phoneix Yellow ITR that was right-hand drive (UK or Aussie-spec I assume, they were not power folding). That won't work on a LHD car so I swapped the mirrors and housings over to the triangular bases from my car and it works great.
Old Mar 9, 2006 | 07:23 AM
Solscud007's Avatar
Default Re: (PatrickGSR94)
I I noticed that I will have to depin the harness. how do you do that?
Old Mar 9, 2006 | 08:24 AM
super jdm yo's Avatar
Default Re: Cheap jdm power folding mirrors (Solscud007)
so what's the process of taking out the mirror?
Old Mar 9, 2006 | 09:02 AM
Solscud007's Avatar
pop out the mirror cause you need to access the screws. unscrew the screws and the two halves will come apart.
Unscrew the three scews where the hinge is at the bottom of the mirror hinge.
remove the rubber seal/gasket on triangular base
un pin the harness in the triangular base
and then swap over your stock mirror housings.
Old Mar 9, 2006 | 09:09 AM
redGSRguy's Avatar
Default Re: (Solscud007)
Were you able to complete the swap? I need new mirrors since the base of my drivers side shakes like crazy since I think something is broken inside!
Old Mar 9, 2006 | 09:48 AM
Default Re: (redGSRguy)
sorry for the confussion, i was wondering how to take the mirror off? is ther a special way? because i dont want to break it just trying to take it off.
Old Mar 9, 2006 | 10:22 AM
shyboi4u's Avatar
Old Mar 9, 2006 | 12:58 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: (shyboi4u)
wish i knew this about a week ago, my folding mirrow are in the shop right now. But i got them for 150 bucks including everything except the relay.
One question can/how do you take out the mirror ? Can the US ones be put on the jdm ones ?
Old Mar 10, 2006 | 05:02 AM
EnjoyTheRideDC2's Avatar
Default Re: (00IntegrAllmotoR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR &raquo;</TD></TR><TR><TD CLASS="quote">wish i knew this about a week ago, my folding mirrow are in the shop right now. But i got them for 150 bucks including everything except the relay.
One question can/how do you take out the mirror ? Can the US ones be put on the jdm ones ?</TD></TR></TABLE>
I thought we spoke about this before, didn't we???
Removal of Glass from mirror housing:
Mirror - Actual glass piece: JDM/USDM
-You have to use the USDM Glass piece on the JDM Black Plastic Panel. In other words, you need to seperate the glass from its plastic panel and swap them over.
Modified by EnjoyTheRideDC2 at 6:42 AM 3/10/2006
Old Mar 10, 2006 | 05:13 AM
reno96teg's Avatar
i guess you guys don't know this...
the mirror changed in appearance in 96 and up. it's 94-95 that have the smooth back.
Old Mar 10, 2006 | 06:16 AM
Solscud007's Avatar
Default Re: (reno96teg)
are you sure it is 96 and up? I thought the non smooth ridge thing were only 98+
Old Mar 10, 2006 | 06:31 AM
reno96teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solscud007 &raquo;</TD></TR><TR><TD CLASS="quote">are you sure it is 96 and up? I thought the non smooth ridge thing were only 98+</TD></TR></TABLE>
positive. i mean, i see it all the time, but also, my integra is a '96, and i have the ridge.
Old Mar 10, 2006 | 08:09 AM
Reno is right.....I have a 97 and also have the ridge. It was a 96-up design.
Old Mar 10, 2006 | 08:52 AM
Taristin's Avatar
Yep. 97 here, with the ridge.
Old Mar 10, 2006 | 09:12 AM
Solscud007's Avatar
Default Re: (Taristin)
oh ok. I thought they only came on 98 up thanks
here is a pic of the JDM foldng actuator and UDM actuator. this is what you are swapping out.
JDM on top
Old Mar 10, 2006 | 09:27 AM
SUPREME!'s Avatar
Old Mar 10, 2006 | 10:32 AM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solscud007 &raquo;</TD></TR><TR><TD CLASS="quote">oh ok. I thought they only came on 98 up thanks
ah very good to know... I knew it looked different somehow but couldn't remember what it was exactly.
Old Mar 10, 2006 | 02:42 PM
HT Black OPs
thanks for the instructions, but i just called my shop today and they said the mirrors are already done. You live and you learn. Does anyone have a DIY to hooking these babies up ? To OP nice write up.
Old Mar 10, 2006 | 03:00 PM
integra DC4's Avatar
So if I wanted the 96+ ridge style, all I have to do is swap the outer plastic part? Would this be the same for USDM ones where I can probably get them at the junkyard?
Old Mar 10, 2006 | 03:16 PM
Solscud007's Avatar
Default Re: Cheap jdm power folding mirrors (TEGG DC4)
yes.
RUCHO01
Apr 30, 2009 08:09 AM
jcsurfer8386EF
16
Jan 12, 2009 04:13 PM
Draggin99Si
10
Jun 21, 2007 03:10 PM
Backk InTheDA
Dec 8, 2005 08:48 PM
cascaritas
Jun 30, 2005 03:51 PM
