D Series tranny mated with b series Engine ?
Old Mar 8, 2006 | 08:27 PM
PrestonCRX's Avatar
Default D Series tranny mated with b series Engine ?
D Series tranny mated with b series Engine ? is it poss ? is there an adapter plate out there for it ? if so can someone hook me up with a link?
Old Mar 8, 2006 | 08:31 PM
gnar kill's Avatar
Default Re: D Series tranny mated with b series Engine ? (PrestonCRX)
I have never heard of someone doing it....but anything is possible....
Old Mar 8, 2006 | 08:45 PM
Bjorn20's Avatar
um, what d series tranny with what b series motor? because d series is cable, and some b series is hydralic, (ctr, itr, gsr motors)
dont know why you would want to attempt something like that, if its even possible, i honestly dont think it is possible, and dont actually see the point of it, mainly because of the lsd option with b series trannys over d series.
Old Mar 8, 2006 | 09:18 PM
The Ricer's Avatar
almost positive its not possible without some major modification that isnt worth it at all
Old Mar 8, 2006 | 10:27 PM
Donkey85's Avatar
Default Re: (SonicEdge)
yes it can be done with the adapter plate from bisimoto
Old Mar 8, 2006 | 10:33 PM
.Grimace's Avatar
footwork mastery
Default Re: D Series tranny mated with b series Engine ? (Bjorn20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bjorn20 &raquo;</TD></TR><TR><TD CLASS="quote"> because d series is cable, and some b series is hydralic, (ctr, itr, gsr motors) </TD></TR></TABLE>
um, what d series has cable and hydro my friend. and also b series has cable and hydro too
Old Mar 9, 2006 | 03:34 AM
Twilight's Avatar
Default Re: D Series tranny mated with b series Engine ? (PurpleEKHatch)
Even if it would mate to the B- engine. Why in the world you would want this? You can easily f*ck up the potential of the motor if you select a wrong tranny.
Stay B if you want to run B correctly.
Old Mar 9, 2006 | 03:43 AM
StorminMatt's Avatar
Default Re: D Series tranny mated with b series Engine ? (Twilight)
Not to mention the cost of the adaptor plate (if anyone even makes one). It has to cost at least $500. And then you are getting a weaker transmission (I don't care what anyone says), less desirable gearing, and unequal length axles. It's just not worth it.
Old Mar 9, 2006 | 05:27 AM
Crimson_Tide's Avatar
Default Re: D Series tranny mated with b series Engine ? (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Donkey85 &raquo;</TD></TR><TR><TD CLASS="quote">yes it can be done with the adapter plate from bisimoto</TD></TR></TABLE>
+1... d series and b series both came with cable and hydrolic transmissions, there are also transmissions for both motors that came with a factory lsd setup... and btw i believe that a zc transmission has equal length axles ... i dont think that the bisimoto adapter plate would cost that much... more like $100-200... IMO it would be worth it if you already had a zc trannsmission with lsd... im pretty sure that their gearing is even shorter than a B16 and would be a better choice for acceleration
-Josh
Old Mar 9, 2006 | 06:07 AM
4thgenhtch's Avatar
Default Re: D Series tranny mated with b series Engine ? (dEaF_HATCH)
Not to mention blowing up a b series tranny will run you 500 and up in my area, I got 5 d series trannies in my storage
jseaton357
55
Oct 15, 2017 02:32 AM
thegatekeeper14
Welding / Fabrication
Dec 20, 2009 06:25 PM
TXGrunt
13
Dec 13, 2007 11:57 AM
JDM_EK4_Coupe
Apr 15, 2007 07:50 PM
mrnice1058
Dec 10, 2004 05:53 AM
