Knock sensor wiring non-vtec --> Vtec
Old Mar 8, 2006 | 07:54 PM
GR_DC2's Avatar
Default Knock sensor wiring non-vtec --> Vtec
For the knock sensor, should i just wire it directly from the knock sensor plug to the correct pin in the ecu harness?
The only reason i question this is because of the harness i am using. I have a 97 B18b1, and i am swapping a B18c1. HOWEVER, the B18c1 was in a 96 Civic. So i basically just removed all of the wiring so i could hook them up to my harness (IACV, VTEC oil pressure, and VTEC solenoid). The last one is the knock sensor.
But when i went to go pull the knock sensor wire out of the GSR harness, it was a red/blue wire and i followed it to where there is a brown wire tapped off of it (this is a factory/oem tap too). the brown wire goes to a brown harness and ends there. The red/blue knock sensor wire is covered in a thick blue wire cover and it goes directly to the knock sensor plug.
So my queston is, do i need that brown wire when i wire the knock sensor up to my B18b1 ecu harness, or do i just wire the knock sensor directly up to the ecu harness and not worry about the brown wire that is tapped off of it? thanks for reading.
Old Mar 9, 2006 | 11:36 AM
GR_DC2's Avatar
no luck yet...
Old Mar 9, 2006 | 12:12 PM
Bspec18's Avatar
Default Re: Knock sensor wiring non-vtec --> Vtec (Aznspeedracer)
just use 1 wire to the correct pin and the 2nd wire ground.
Old Mar 9, 2006 | 12:29 PM
GR_DC2's Avatar
Default Re: Knock sensor wiring non-vtec --> Vtec (Bspec18)
so u think that brown wire is just a ground then? if so, that is nice and simple.
redline5th
Jul 5, 2010 09:34 PM
crxb16ftw
May 23, 2007 09:32 PM
phanatic
May 18, 2007 02:21 PM
TurBoTeG
Jan 15, 2004 05:16 PM
devonic
10
Apr 9, 2003 09:53 AM
