Del Sol Maintenece Questions
I just picked up my new del sol tonight. Its a 93 SI. I dont have the owners manual, and incase I cant find a haynes this weekend, I had some basic maintence questions, that if someone could answer I would be very appreciative!
Oil Capacity?
Tranny Oil Capacity
Tranny Oil Type? (I assume its 5-30 like my teg was, so I can use redline MTF?)
OEM Tire Size
That should get me through the weekend
I am so exicited. Driving it home tonight really made me miss my teg
but now I have a new toy to play with!
Couple of other questions
The oil leak around the valve cover, I assume is the same valve cover gasket problem that all honda's have?
I have this grinding noise coming from the tranny, its intermittent, but very loud, and goes away when the clutch is pressed in. I dont know if its the input shaft or something from the clutch. This car sat for awhile and hasnt been driven that much in the last 2 years, so I need to drain and replace alot of fluids!
Oil Capacity?
Tranny Oil Capacity
OEM Tire Size
but now I have a new toy to play with!Couple of other questions
185/60/R14 is the size on my tires on my 93 Si, but I'm not entirely sure if that is what the stock size is. I haven't had any problems with these though =P
As for oil capacity, I put 4 liters plus .5 liters of Lucas Oil Additive in last time I changed so I guess it could be anywhere from 4-4.5 This put me right at the second dot by the way =/
I've got a full set of Sol manuals, but they changed engines in 96 and my set is for 97.
Most (all?) of the engines & transmissions used in the Sol were used in other Hondas, so you could peek into the engine bay, write down the engine & transmission codes, and from there I bet the info you want would be in older H-T threads.
FWIW, I have the same erratic noise from my transmission, and it's the input shaft bearing. My throwout bearing has been replaced, lubed, & replaced, so I'm damn sure it's not the throwout bearing. For the most part - noise when the clutch is depressed normally means the throwout bearing, noise when the clutch is released normally means input shaft bearing. (for a noise that goes away based on pedal position)
Good luck with your purchase, hope she turns out to be as reliable as mine.
93 del sol si2
165
May 19, 2013 07:04 PM
brianandlydz
Apr 27, 2007 11:07 PM
del sol1658
May 17, 2006 09:18 AM
