Just switched to 750cc rc's and seems to be flooding plugs?help please?
Old Mar 8, 2006 | 03:34 PM
B18ceed's Avatar
Default Just switched to 750cc rc's and seems to be flooding plugs?help please?
i am using hondata and just bumped the boost up to 14lbs and so we threw 750 rc's and we tuned the car and everything went fine but parked it overnite and wouldnt start?im using bk8eix iridium plugs and there getting flooded everytime.help is greatly appreciated
Old Mar 8, 2006 | 04:38 PM
ccivic's Avatar
Default Re: Just switched to 750cc rc's and seems to be flooding plugs?help please? (B18ceed)
FPR. Replace it and see if it fixes it.
Old Mar 8, 2006 | 04:56 PM
B18ceed's Avatar
Default Re: Just switched to 750cc rc's and seems to be flooding plugs?help please? (ccivic)
i have an b/m adjustable fpr, i have 40psi of fuel pressure at idle too much?
Old Mar 8, 2006 | 05:03 PM
ccivic's Avatar
Has your pressure changed from what is was previously? My brother's car did the same thing when his FPR went bad.. replaced it and it fixed the problem.
What're your plugs gapped to? Try a cheap set of BKR7E's if everything else is right. What's your ignition setup? People have had a lot of problems with a lot of the MSD equipment.
Old Mar 8, 2006 | 05:28 PM
B18ceed's Avatar
i have stock ignition i believe only 8 degrees of timing, will bringing down the fuel pressure do any justice? i use to run 370cc and an afc never had a problem starting the car and that was with the cheap7es plugs
Old Mar 8, 2006 | 06:18 PM
machine4321's Avatar
was your hondata reprogramed to run the 750s
if its still set for the last ones it wont work to good
turbochic
Sep 4, 2003 01:30 PM
DLOTYPER
Jan 28, 2003 11:19 AM
XES
Sep 21, 2002 12:47 PM
forcedaccord95
Aug 7, 2002 07:40 AM
