Question: fiting itr 5 lug to canadian 2000 acura 1.6 el 4dr (4dr civic ex)
like i mentioned, i've got a 2000 acura 1.6 el 4dr (up-scale model of 4dr civic, with 1.6L sohc vtec driveline).. anyway, i wanted to know how easy is it to convert the suspension to itr 5 bolt? can i use the stock shocks, lca's?? which e-brake cables will i need??
someone please help me out. i'd like to swap the set-up, but i want to know what i'm getting into before i start spending the cash
thanks
thanks
Yes, it will bolt in. You can use stock struts with your stock LCAs. If you get CTR LCAs, you need Type-R struts. Use the ebrake cable from a 99-00 SiR, unless your EL came with rear disk brakes, use that ebrake cable.
jspinelli8
Jun 4, 2017 08:57 PM
JDM honey
Oct 4, 2007 08:59 AM
jeddy0120
Aug 1, 2007 01:15 PM
compwc18
Apr 9, 2005 03:54 AM
ultradx
Jan 21, 2003 10:59 AM
