EH3/EG6 Surging/low idle
Old Mar 8, 2006 | 03:09 PM
Earthworm Jim's Avatar
Default EH3/EG6 Surging/low idle
Now I have done a search, there are so many different catergories that come up and none of the title really say what the topic is. This should make the search easier for someone else in the future.
Now, on a cold morning, the motor revs up to 2500rpms lowers about 300rpms then goes back up to 2500. It surges up and down like that as the car is warming. After the car is warm the car will idle right about being off. I'm not popping any codes, I've checked all my vaccum hoses and adjusted the screw on the throttle body, any suggestions?
Old Mar 8, 2006 | 03:10 PM
Default Re: EH3/EG6 Surging/low idle (The_General)
edit:
Old Mar 8, 2006 | 03:43 PM
Help me please........please help me.
Old Mar 8, 2006 | 03:45 PM
Tatakai's Avatar
is it a really slow surge, compared to a vacuum leak? check your plugs. i've heard bad/going bad spark plugs can lead to a slow bouncing idle when cold. there's a chance it could be your O2 sensor.. but that will usually throw a code
Old Mar 8, 2006 | 10:08 PM
EJ1_203's Avatar
put some coolant in that bad boy!
Old Mar 9, 2006 | 09:37 AM
Default Re: EH3/EG6 Surging/low idle (Tatakai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1_203 &raquo;</TD></TR><TR><TD CLASS="quote">put some coolant in that bad boy! </TD></TR></TABLE>
The coolant is topped off, do you think that I need to have it changed or what?
Old Mar 9, 2006 | 09:58 AM
tl hatch's Avatar
Go here ...
https://honda-tech.com/zerothre...1099
Old Mar 9, 2006 | 10:20 AM
ZipTieGUy's Avatar
behind your intake mani is your idle air control valve. its held on by 1 10mm bolts. remove them and remove the two vaccum lines, and plug. you will see a little filter that is probly clogged up with ****. use a toothbrush or flat head and scrape that dirty **** out. spray some carb clean in it and in your itnake manifold. when you start up your car it will stall and act a little weird for 2 minutes then after that your idle will be coo. how do I know because I just did it
Old Mar 9, 2006 | 10:22 AM
Default Re: (ZipTieGuy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZipTieGuy &raquo;</TD></TR><TR><TD CLASS="quote">behind your intake mani is your idle air control valve. its held on by 1 10mm bolts. remove them and remove the two vaccum lines, and plug. you will see a little filter that is probly clogged up with ****. use a toothbrush or flat head and scrape that dirty **** out. spray some carb clean in it and in your itnake manifold. when you start up your car it will stall and act a little weird for 2 minutes then after that your idle will be coo. how do I know because I just did it</TD></TR></TABLE>
Any pictures?
Old Mar 9, 2006 | 10:24 AM
HalfAnP's Avatar
From: I put on my robe and wizard hat, NY...err Bay Area--->Texas
This is true. The same thing was happening to me, and I cleaned out the IACV and the FITV. Problem solved.
Old Mar 9, 2006 | 10:26 AM
ZipTieGUy's Avatar
wtf is a FITV
Old Mar 9, 2006 | 10:28 AM
ZipTieGUy's Avatar
Default Re: (The_General)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_General &raquo;</TD></TR><TR><TD CLASS="quote">
Any pictures?</TD></TR></TABLE>
its friggin easy. you just need a 10mm socket and ratchet. also some pliers to undo the hose clamps. and you may have to squat on your engine to do it, space is limited
Default Re: (HalfAnP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HalfAnP &raquo;</TD></TR><TR><TD CLASS="quote">
This is true. The same thing was happening to me, and I cleaned out the IACV and the FITV. Problem solved.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZipTieGuy &raquo;</TD></TR><TR><TD CLASS="quote">wtf is a FITV</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_General &raquo;</TD></TR><TR><TD CLASS="quote">Any pictures?</TD></TR></TABLE>
Old Mar 9, 2006 | 10:46 AM
HalfAnP's Avatar
Fast Idle Thermo Valve. sits immediately UNDER the throttle body. The IACV is Behind The TB, facing the firewall. Sorry guys, no pics.
Old Mar 9, 2006 | 10:53 AM
tgreaves's Avatar
Fitv would be my guess also..
What we always do it just remove the valve and either fill the valve with jbweld or cut a beer can open and trim it down so that it covers the holes..
On my TB I just filled the holes in the TB and left the fitv off of it.. Youll just have to hold on the gas for like 5 secound after you start the car cold to keep it running, and I only have to do that when its cold outside.. Actually now I just compensate for it with my AEM EMS..
Dirtfall
Feb 1, 2007 08:54 AM
dc4g
Nov 24, 2005 10:04 AM
DarkBB4
Aug 26, 2005 12:31 PM
RedStarGsr
Jan 7, 2004 12:01 PM
