crx seats in hatchback???
Old Mar 8, 2006 | 01:14 PM
EF9 JAMS!!!'s Avatar
Default crx seats in hatchback???
so i found some crx si seats and well, first off i know that the seat rails don't work but i really think these seats would look clean in my car (htach) and would like to know if there's a way this can be done....surely someone has done it before, looking for some help.
Old Mar 8, 2006 | 10:35 PM
wildercard's Avatar
Default Re: crx seats in hatchback??? (hatch91JDM)
I thought about doing this for a while.....then i came across mint si seats.....which is what i would recommend u do. The thing that turned me off from putting the crx seats is that you will not be able to get rear seats that will match. However if you want to do this you have, as far as i know, 3 ways to do it.
1: drill holes in the body of the car and mount the seats with its own rails (not recommended)
2: weld brackets on the crx seat floor pan so it lines up with your car
3: swap the seat floor pans, this is what i would recommend
Old Mar 8, 2006 | 10:36 PM
square_1's Avatar
Go with the Si seats!!!
Old Mar 9, 2006 | 04:53 AM
Mugencrxsir1's Avatar
Default Re: crx seats in hatchback??? (square_1)
they will work with slight seat modification
Old Mar 9, 2006 | 05:31 AM
haggar's Avatar
I did it once, swapped the seats from my 90 CRX Si into a 91 STD...
The rails were all wrong for the Civic. I forget exactly what I did. I believe I removed the Civic rails, modified them to fit the CRX seat pans. I think, though, that one part I ended up welding the rail to the pan, because the parts rubbed/squeaked when you sat on it.
There used to be writes up on this board somewhere... oh, about 3-4 years ago, when I did the swap..
Old Mar 9, 2006 | 12:57 PM
meseetree's Avatar
I have CRX seats in my hatch.
modified the pans. also don't care about not having rear seats because the car is fully gutted.
Old Mar 9, 2006 | 01:14 PM
dohccrxsi's Avatar
I put 93 Del Sol Seats in my CRX, And I had to Take the CRX Rails off the original Seats, and Build a Frame for the del sol seats to sit on, and then A buddy of mine Welded them onto the Rails, The Difference between the 2 Sets of Seat Rails between Civic & Crx is the Mount point on the rear of the seat on the E Brake Side, I'd personally try to take the civic rails, Drill out the crx seats to match them, and bolt them up that way, make sure you have the seats lined up on the rails, or they will not slide right.
Old Mar 9, 2006 | 04:03 PM
Default Re: crx seats in hatchback??? (wildercard)
is it hard to swap out the whole entire seat pan???
Old Mar 9, 2006 | 04:11 PM
wildercard's Avatar
i never tried it myself but from what i know it is not difficult at all. i think you have to take the seats apart first using hex keys, then use needle nose pliers to remover the metal hooks that are holding the pan to the seat. If you are going to do this, first try this on your old seats...that way if you cant put it back together you will know either not to do it to the crx seats or learn how to do it.
Old Mar 9, 2006 | 04:13 PM
well is the cloth underneath the crx seats going to be enough to cover the civic seat pan...cause it kinda looks a little wider
Old Mar 9, 2006 | 04:23 PM
wildercard's Avatar
like i said, i have never done this, but i know it has been done..... there used to be a write up on this, but i no longer have it nor do i know where i got it from...try searching the net and maybe you might find it. As far as the matterial goes, i think you should be able to stretch it and make it fit.........if you really want to do it, try it out, if it does not work you should be able to put back the original pans
Old Mar 9, 2006 | 05:33 PM
I'M GONNA DO IT!!! and then i'll make a write up about it.
Old Mar 9, 2006 | 06:18 PM
meseetree's Avatar
I'll take pics of mine on saturday.
I'm pulling the whole motor out so a seat isn't any extra work.
Old Mar 9, 2006 | 07:13 PM
wildercard's Avatar
goodluck and let us know how it goes
CrxKid88SiR
Apr 11, 2015 08:24 AM
crxalx
Dec 16, 2009 11:36 AM
shortbuss90
Feb 18, 2008 08:26 AM
si0385.
Jan 4, 2006 03:34 PM
BlackNoise
10
Sep 24, 2004 07:04 PM
