clutch problem
Old Mar 8, 2006 | 10:59 AM
efyou's Avatar
Default clutch problem
i jus put a diff s1 trans with a BRAND NEW clutch in...and for some reason i cant get the cable to adjust it to where it starts engaging a lil lower...like if i jus rest my foot on the pedal my clutch slips when i hit the gas kinda hard...any suggestions?
Old Mar 8, 2006 | 11:10 AM
deucedeuceEK's Avatar
Default Re: clutch problem (efyou)
hmmm dunno. But aren't you supposed to break in your clutch before you start smahing on it?
Old Mar 8, 2006 | 11:12 AM
efyou's Avatar
Default Re: clutch problem (EF-LS-HATCH)
well its broke in...becuz its seems like so out of adjustment that its riding it all day long.
Old Mar 8, 2006 | 06:02 PM
efyou's Avatar
bump
Old Mar 9, 2006 | 08:27 AM
efyou's Avatar
bump
Old Mar 9, 2006 | 04:20 PM
efyou's Avatar
any1?
Old Mar 9, 2006 | 05:09 PM
mahatma's Avatar
You've got to loosen that cable somehow. Maybe the bracket got bent and is pulling it too tight beyond the point of adjustment......
Old Mar 9, 2006 | 05:19 PM
RCautoworks's Avatar
Why can't you loosen the cable ?
Old Mar 10, 2006 | 06:37 AM
efyou's Avatar
Default Re: clutch problem (mahatma)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahatma &raquo;</TD></TR><TR><TD CLASS="quote">You've got to loosen that cable somehow. Maybe the bracket got bent and is pulling it too tight beyond the point of adjustment......</TD></TR></TABLE>
which way would it have got bent to do this? up or down? also i CAN adjust it...but it doesnt seem to make a difference
Old Mar 10, 2006 | 09:11 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efyou &raquo;</TD></TR><TR><TD CLASS="quote">
which way would it have got bent to do this? up or down? also i CAN adjust it...but it doesnt seem to make a difference</TD></TR></TABLE>
Make sure the nut is spinning and the threaded part is not.
Old Mar 11, 2006 | 08:35 AM
efyou's Avatar
Default Re: clutch problem (90blackcrx)
well...it spins...and adjusts only where it DISengages...where ENgages is always way at the top of the pedal which it wasnt like that before i put the other trans in so, im still stumped
Oreo-TeCk
Aug 31, 2009 06:14 PM
exz0n-.-
Jan 6, 2009 06:53 PM
ThaMatrix
Jun 7, 2005 03:15 PM
Slvr_CRX
Dec 13, 2004 10:08 AM
Steve90HB
Feb 14, 2004 07:38 AM
