p28 code 43.
Old Mar 8, 2006 | 09:55 AM
Elevorett's Avatar
Default p28 code 43.
I did my obd swap, using all the proper materials ex. jumper harness, dizzy harness, and all properly heat shrinked. I boughta brand new 4-wire o2 sensor, and I am getting the code #43. Can anyone relate? Or have any informationasto what else it could be? (ps, code 43 = fuel system)
Old Mar 9, 2006 | 11:45 PM
Elevorett's Avatar
any takers?
Old Mar 10, 2006 | 11:42 AM
Elevorett's Avatar
well i'll update, i bought a new fuel filter, thinking that might be the issue. I will keep updating. Also, I reset my ECU, no luck there. Sigh.
Old Mar 10, 2006 | 03:14 PM
SECURITY's Avatar
Default Re: (Elevorett)
I have the same set up as you... I've thrown a code 43 for over a year now and have never really cared to make repairs to it. Did it start right after you changed the O2 sensor? It could also be the fuel pump which is mainly why I said fugg it.
There's a lot of threads already on this that I looked into when I first had this happen to me
Old Mar 11, 2006 | 07:46 PM
Elevorett's Avatar
thanks, up for answers!
Old Mar 12, 2006 | 07:21 PM
SECURITY's Avatar
bumps y0. Someone help this guy
Old Mar 12, 2006 | 08:01 PM
SECURITY's Avatar
Default Re: (SECURITY)
I guess this thread is invisible
edit: I spelt invisible wrong
Modified by SECURITY at 9:30 PM 3/12/2006
Modified by SECURITY at 9:31 PM 3/12/2006
Old Mar 12, 2006 | 08:12 PM
uglyrex's Avatar
was the car a dx? i am doing a swap too and almost shure having fule pump on same leg as fuel injetors has too much of a voltage drop across the terminals
take a look at the pics they are from mitchell
one is a dx main relay other is from a mpfi car most all of the sites do not mention this when doing a mpfi swap maybe its not a issue with obd0 but i feel shure its a concern with obd1 being a better system!
Old Mar 12, 2006 | 08:49 PM
speeddave's Avatar
Default Re: (uglyrex)
nope the car is an si. did you set the timing yet?
Old Mar 15, 2006 | 05:27 PM
xtrafastcivic's Avatar
Default Re: (speeddave)
code 43 usually is the o2 sensor change it and reset the ecu and see what happens.. (borrow a friends)
SlowB20z
Engine Management and Tuning
Dec 28, 2012 09:12 AM
hondaboy9506
Sep 24, 2010 10:20 AM
Rudelude22
Sep 29, 2005 10:20 AM
PhilStubbs
Jan 22, 2005 11:20 AM
