Is there ANYTHING you can do to make the stock airbox breathe better?
Old Mar 8, 2006 | 09:24 AM
Jason703Racing's Avatar
Default Is there ANYTHING you can do to make the stock airbox breathe better?
Looking for a way to make my engine bay look stock but still be able to breathe a little better then the stock restrictive way. Is there anything you can do with the air box/piping to make it breathe a little better?
Old Mar 8, 2006 | 09:28 AM
SVOboy's Avatar
Some people drill holes in it?
Old Mar 8, 2006 | 09:34 AM
EFstyle's Avatar
Default Re: (SVOboy)
that ^ and buy a spoon filter insert or somthing...
Old Mar 8, 2006 | 09:36 AM
AutoXer's Avatar
The only real 'bad' part of the intake system is the resonator. You could pull out that part of the piping, but then you'd loose the benefit of the piping pulling in cold air from behind the headlight. I'd just throw a K&N in there and call it a day.
Old Mar 9, 2006 | 01:57 PM
Default Re: (AutoXer)
i thought the airbox/resonator box was all one unit on the em1 i could be wrong though so... yea... but yea.. let me know ill pull it off tonight if its 2 units
Old Mar 9, 2006 | 02:44 PM
johnecon2001's Avatar
Default Re: (Black00EM1)
You can cut the bottom off of it, pretty ghetto IMO but whatever.
You could also look into a Comptech Icebox. Keep the stock arm from your stock box and use it in conjunction with the icebox. Viola! Better flow with a stock look.
Old Mar 9, 2006 | 03:22 PM
wrinkles's Avatar
just take out the airbox, thats what i did on my civic for a while, then i got an intake
Old Mar 9, 2006 | 03:25 PM
Hondaciv95VX's Avatar
Default Re: (wrinkles)
I cut the bottom of my box, gheyto...so I removed the resignator, and was better (coverd the whole I had cut) But I wanted some cooler air, so I got some flexi pipe and dropped it from the intake box's hole to the bumper. I used it for about 6+ months, not a single problem...car did run colder, and had a slightly differnt tone.
Old Mar 9, 2006 | 03:29 PM
db8gsr_teg's Avatar
Default Re: (johnecon2001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnecon2001 &raquo;</TD></TR><TR><TD CLASS="quote">
You could also look into a Comptech Icebox. Keep the stock arm from your stock box and use it in conjunction with the icebox. Viola! Better flow with a stock look.</TD></TR></TABLE>
Old Mar 9, 2006 | 04:34 PM
GS-Rcivic's Avatar
Default Re: (db8gsr_teg)
Why not just keep the upper part where the filter goes in and take off the rest of the snake looking pipes. I did that and still gets air from the hole thats on there.
Old Mar 9, 2006 | 05:50 PM
EG2Driver's Avatar
Default Re: (GS-Rcivic)
Took everything out but the filter housing. [IMG][/IMG]
Old Mar 9, 2006 | 05:53 PM
yoohoo's Avatar
Default Re: (deadend9009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadend9009 &raquo;</TD></TR><TR><TD CLASS="quote"> Took everything out but the filter housing. [IMG][/IMG] </TD></TR></TABLE>
thats pretty retarded
Old Mar 9, 2006 | 06:00 PM
EG2Driver's Avatar
Default Re: (Personal Information)
oh well.....retarded or not, thats what im stuck with. peace.
Old Mar 9, 2006 | 06:19 PM
JCracer723's Avatar
wow... so yeah.. speechless
Old Mar 9, 2006 | 07:27 PM
BudgetBalla's Avatar
Default Re: (JCracer723)
I replaced the stock plastic piping from the tb to the box with aluminum piping painted black, then i got another piece of pipe, which was originally a U bend, cut that in half, so i had an L shaped pipe. I used a plumbing clamp and secured that piece into the bottom of the box. Long end into the box, short piece pointing to the front of the car. The pipe sits right in between a part of the car and my rad. It is my version of a ghetto home-made icebox btw, it is very quiet!
Old Mar 9, 2006 | 07:28 PM
Default Re: (BudgetBalla)
Forgot to mention, Accel Cool Blue performance filter inside the box, 15 bucks from ebay
Old Mar 9, 2006 | 08:50 PM
elitesi8's Avatar
Hot air= bad
cool air= good
You are getting more Hot air now.lol
Old Mar 9, 2006 | 10:36 PM
built562's Avatar
Default Re: (elitesi8)
1.) get a JDM eg civic air intake arm, only the arm because the box is the same, but the arm is larger in diameter. (not cuz its JDM )
2.)then remove the resonator and take some black air ducting and rout it to the bottom of the air box where the resonator was and take the other end and route it to the front bumper,
3.)then use a drop in hi flow filter like k&n
Old Mar 9, 2006 | 10:56 PM
Guam_CiviC619's Avatar
Default Re: Is there ANYTHING you can do to make the stock airbox breathe better? (Black00EM1)
1st of all what engine are we talking about here? An aftermarket dropin would be a good place to start.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elitesi8 &raquo;</TD></TR><TR><TD CLASS="quote">Hot air= bad
cool air= good
You are getting more Hot air now.lol </TD></TR></TABLE>
Well, he may be getting hot air @ idle and low crusing speeds (20 and below), but while moving, I'm pretty sure it is somewhat benificial. Nothing wrong with looking for "free power".
Old Mar 9, 2006 | 10:59 PM
GarageAlchemist
Guest
Posts: n/a
Default Re: Is there ANYTHING you can do to make the stock airbox breathe better? (Guam_CiviC619)
just buy an intake off ebay.. seriously its 30 bucks shipped..
Old Mar 10, 2006 | 12:05 AM
Fugun's Avatar
yes.. ive never seen this before.. quite creative
Old Mar 10, 2006 | 01:08 AM
zoolander's Avatar
Default Re: (Fugun)
just take off all the resinator piping...it still draws in colder air than the engine bay. and of course swap filters.
Old Mar 10, 2006 | 02:49 AM
Syndacate's Avatar
what's your reasoning for "upgrading" your...air box rather than just getting a good CAI?
Old Mar 10, 2006 | 01:56 PM
built562's Avatar
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">what's your reasoning for "upgrading" your...air box rather than just getting a good CAI?</TD></TR></TABLE>
he said he wanted it to look stock. i had my semi bult swap looking stock due to hoods being popped so much around here. engine sleeper look
Old Mar 11, 2006 | 02:01 PM
EG2Driver's Avatar
Default Re: (built562)
cai u run the possibility of hydrolocking. I dont, even if my intake looks gay, its free and it works.
