Slight issue with h22 crank pulley
Old Mar 8, 2006 | 04:10 AM
djnikko's Avatar
Default Slight issue with h22 crank pulley
I have noticed is there is a little notch out of the edge of my h22 crank pulley. I am wondering if this is going to affect the balancing? I have a welder friend who could fill it in and file it down but would this be nessacary? I dont want the pulley to crack over time.
Or I could plug it with a little JB weld?
Also the machine shop painted my crank pulley and now I cannot see the timing marks, I have an aftermarket crank pulley which I wont be using but surely I can use this to find out where the markings could be on the other pulley, is it worth using a potractor (you know the device you used in school to measure angles)
Thanks in advance
Old Mar 8, 2006 | 12:00 PM
b16hybridsol's Avatar
Default Re: Slight issue with h22 crank pulley (djnikko)
timing marks are on the flywheel. the motor will probably live but it'd be cheap insurance to get a new one
atlplayer4life90
Nov 15, 2007 12:11 PM
ilovemydc5
Feb 2, 2007 01:24 AM
spooned out
Aug 26, 2006 08:36 PM
zracer240
Jan 20, 2006 07:29 AM
94TealGSR
Jan 3, 2003 08:23 PM
