96 civic losing oil
Old Mar 8, 2006 | 03:36 AM
shortyscivic's Avatar
Default 96 civic losing oil
ok guys heres the story i just bought a 96 civic ex and it has 190,000 miles on it. 2 questions i cant find anywhere what the motor is and it loses a qt of oil every 1000-1500 miles anyone have that problem or know if its normal or should i get it checked out
Old Mar 8, 2006 | 04:37 AM
old man neri's Avatar
Default Re: 96 civic losing oil (shortyscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortyscivic &raquo;</TD></TR><TR><TD CLASS="quote">ok guys heres the story i just bought a 96 civic ex and it has 190,000 miles on it. 2 questions i cant find anywhere what the motor is and it loses a qt of oil every 1000-1500 miles anyone have that problem or know if its normal or should i get it checked out</TD></TR></TABLE>
Whatever you do I wouldn't put too much money in that engine. That is a very "tired" engine. It has probably had a long and hard life. Just my $0.02
Cheers
Old Mar 8, 2006 | 05:06 AM
sicky's Avatar
grammer nawzi
Doesn't sound too bad. My B16 loses around a quart every 1000-1500, but granted I am running a higher compression motor and use synthetic.
Old Mar 8, 2006 | 05:13 AM
PullinGeeees's Avatar
do you run the motor hard? when you run a car at wot all the time it tends to suck oil from the pcv valve into the motor to help lube the top of the pistions and rings... It may also have worn out rings or valve gide seals that are leaking inside the motor just from being old..... thats not a lot of oil... I would just drive it and look for a swap to put in there when that one dies.....
Old Mar 8, 2006 | 05:38 AM
mperezkr's Avatar
check distributor
SGVridgerunner
Jan 3, 2008 01:09 PM
Hemix
Aug 12, 2007 09:32 PM
SyDuck
Mar 10, 2005 10:14 PM
supadupamikey
Sep 1, 2004 10:41 AM
