96 civic losing oil
96 civic losing oil
ok guys heres the story i just bought a 96 civic ex and it has 190,000 miles on it. 2 questions i cant find anywhere what the motor is and it loses a qt of oil every 1000-1500 miles anyone have that problem or know if its normal or should i get it checked out
Re: 96 civic losing oil (shortyscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortyscivic »</TD></TR><TR><TD CLASS="quote">ok guys heres the story i just bought a 96 civic ex and it has 190,000 miles on it. 2 questions i cant find anywhere what the motor is and it loses a qt of oil every 1000-1500 miles anyone have that problem or know if its normal or should i get it checked out</TD></TR></TABLE>
Whatever you do I wouldn't put too much money in that engine. That is a very "tired" engine. It has probably had a long and hard life. Just my $0.02
Cheers
Cheers
grammer nawzi
Doesn't sound too bad. My B16 loses around a quart every 1000-1500, but granted I am running a higher compression motor and use synthetic.
do you run the motor hard? when you run a car at wot all the time it tends to suck oil from the pcv valve into the motor to help lube the top of the pistions and rings... It may also have worn out rings or valve gide seals that are leaking inside the motor just from being old..... thats not a lot of oil... I would just drive it and look for a swap to put in there when that one dies.....
Hemix
08-12-2007 09:32 PM
supadupamikey
09-01-2004 10:41 AM
