gahh..axle won't pop into tranny
Old Mar 8, 2006 | 01:43 AM
crxmadman's Avatar
Default gahh..axle won't pop into tranny
this topic has been posted many times, but unfortunately I've tried many of the tricks so far (many of which involve rubber mallets) and I simply CANNOT get my passenger side axle to fit into the tranny. I've lubed it up, I've tried giving it a lot of english, everything seems lined up properly..
I have the correct axles (the drivers side slid right in like a pita), but this passenger side is a real bitch..
any help fellas?
Old Mar 8, 2006 | 02:06 AM
K20EF8's Avatar
Have a friend help you, one under the car holding and twisting the axles, the other hitting it with a mallet, you just gotta keep doing it until it works and be aggressive with it
Old Mar 8, 2006 | 02:15 AM
crxmadman's Avatar
Default Re: (K20EF8)
i'll give that a shot..thnx
would bolting in the axle nut side first and using the caliper to push the axle in work better maybe? I'll try that as well in the morning
Old Mar 8, 2006 | 06:12 AM
digitally_remastered's Avatar
mine was a pain to put in as well. just take a long rod or a piece of 2x4 get the axle sitting on the tranny inlet partially, place the object on the edge of the axle, and ram the hell out of it until its inside the tranny. youll find out if it stays in or not by just driving around the block. mine poped out once when i was doin 40 on a main road. i had fun popping it back in. lol
Old Mar 8, 2006 | 06:45 AM
Elevorett's Avatar
make sure that your axle has the "circlip" on the end. There will be your threads, and at the very end, there should be a ring that clips onto the threads. When I got my re-manned axle, they forgot to put the clip on, and without the clip, it will NOT stay in the tranny regardless.
Old Mar 8, 2006 | 10:27 AM
crxmadman's Avatar
Default Re: gahh..axle won't pop into tranny (crxmadman)
lol, i guess the universal answer is RAM it in
Old Mar 8, 2006 | 07:34 PM
EFworship's Avatar
when I was changin mine out the shaft got stuck in the tranny because of the circlip,snapring,whatever ya wanna call it. I guess you would wanna make sure there aren't any pieces left in the tranny.
Old Mar 8, 2006 | 07:43 PM
cutt's Avatar
Default Re: gahh..axle won't pop into tranny (EFworship)
count the splines make sure they sold you the right one. happened to a buddy of mine
redman223
Sep 7, 2011 12:15 PM
bmxkills
Jan 30, 2011 08:53 PM
accord99power
May 12, 2009 05:14 PM
*Boostwerks*
19
May 3, 2006 09:20 AM
B18aTegra
May 17, 2004 05:24 AM
