Spoon Style CF Duckbill fitment
i just got my cf duckbill for my eg but one of the screw on the duckbill is crooked and wont go into the hole. what is the best way to fix this? should i drill the hole bigger for the screw to fit in the hole?
a. find another screw.
b. see if where you got it has a return policy. exchange it for a new one and tell them the one you got was retarded.
c.you can find some way to fit it and end up breaking something.
d. i can buy it off you (hahahaha)
try and return it and get one that works.
well what i did when i bought mine the holes were too close together so i just drilled those holes out wider so it fit the right side is a little farther out from the roof but it looks good if you not payin attention. just drill it out and be done with it.
well i heard only 1 out of 10 carbon fiber wings fit perfectly.. so ill try to drill the holes wider.. the screw cannot be replaced, they are attached to the wing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicsareslow »</TD></TR><TR><TD CLASS="quote">well i heard only 1 out of 10 carbon fiber wings fit perfectly.. so ill try to drill the holes wider.. the screw cannot be replaced, they are attached to the wing</TD></TR></TABLE>
word to that..mines has gaps..
some of the wings dont have the screw inside the wing . u have to screw them in i advise u 2 just widen the hole where it wont line up so u can have room line up correctly my girl has a hatch and my friend does 2 her wing went on mint and i had 2 drill his hole out 2 put the wing on .
ok.. after drilling the holes bigger to the left side i finally got the wing to fit.. but there is a gap between the wing and the roof and can see the latch that hooks on to the rear window and the wing
Guest
Posts: n/a
I can't see that on mine, i went and looked. Mine just has a little space on the top part straight across, but other then that it looks about normal. You don't even wanna know how many people have asked to buy that thing off me, the stock wing is so gay and little.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Contender25 »</TD></TR><TR><TD CLASS="quote">I can't see that on mine, i went and looked. Mine just has a little space on the top part straight across, but other then that it looks about normal. You don't even wanna know how many people have asked to buy that thing off me, the stock wing is so gay and little.
yea the stock wing just ruins the look.. im just glad i got my wing to fit after nearly 2 hours of drilling and fitting
</TD></TR></TABLE>yea the stock wing just ruins the look.. im just glad i got my wing to fit after nearly 2 hours of drilling and fitting
lazyguy
Oct 14, 2002 08:17 PM
