Accord Transmission problem
Old Mar 7, 2006 | 11:06 PM
IBriaIN's Avatar
Default Accord Transmission problem
Hi, I recently posted about my transmission problem, and one of the members suggested that I use Honda ATF. The Car shifts smoothly now but when I get into 2nd or 3rd gear it struggles on 4k or 5k RPM the car moves back and forth while driving.
what is the problem? Im scared to go on the freeway now.
1987 Honda Accord Caburated
How much does it cost to rebuild the transmission?
Old Mar 8, 2006 | 03:16 AM
YeuEmMaiMai's Avatar
Default Re: Accord Transmission problem (IBriaIN)
about $2.1K on average
usually breaks down like this
Remove/install labor $550
Parts $1000
rebuild labor $550
Parts most always replaced
Torque converter
All shift solenoids
Main line pressure switch
All clutch packs
All rubber seals
Axle seals
Differential bearings (a must of your car is high milage)
Old Mar 8, 2006 | 04:17 AM
P_Adams's Avatar
Brian, What year was this? Something like an '86 or '87 carbureted 2.0L LX? First thing we must do is determine if the symptoms you describe are transmission related, or engine related; since transmission operation can be adversely effected by a poor running engine.
We've also got to eliminate any conditions which are actually 'normal', and either just weren't working prior, or the thing was so screwed up previously; you just didn't notice. For instance your observation:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IBriaIN &raquo;</TD></TR><TR><TD CLASS="quote">it struggles on 4k or 5k RPM the car moves back and forth while driving. (1987 Honda Accord Caburated) How much does it cost to rebuild the transmission?</TD></TR></TABLE>
This could be the downshift function, or the Torque Converter releasing and applying; either one from input from the gas pedal.
Honda wasn't using the electronic shift 4spd Automatic in 1987 ('90 to present). Yours was a previous generation Tranny. And as such will (most likely) be cheaper to replace that previously mentioned.
As an example; Honda offers a re-manufactured unit for the next years' '88 Accord for an over the counter of (as low as*) $1494.00.
http://www.hondaautomotivepart...20ALL
My sister had her '92 rebuilt at Aamco (of all places) for $1700.00. You could probably find a used unit (with a warranty) for $600.00 / $800.00. Someone in here might be able to hook you up with a good one cheap. You've all manner of avenues; IF it gets that far.
*select dealer Internet pricing (local prices may scare the pants off you )
P
Old Mar 8, 2006 | 05:30 AM
luckyfish1's Avatar
Brian
Make sure you use HONDA ATF! The Honda trans are special and you must use there fluid. It will cost you 2K-3K for a rebuild!
Old Mar 8, 2006 | 07:27 AM
P_Adams's Avatar
Default Re: Accord Transmission problem (luckyfish1)
If you read his first post... he DID use Honda ATF....
I thought the cost of living was high in the Northeast. Remind me not to break down in Roscoe, Illinois
Old Mar 8, 2006 | 10:58 AM
gotricedynasty's Avatar
it is better to buy a tranny that was already rebuilt. i just got one for $300 and it is as good as new!
luismSr
Transmission & Drivetrain
Sep 15, 2014 05:58 PM
OnceIwasMuffin
May 5, 2014 09:36 AM
bigdaddyhonda1
Aug 21, 2013 01:14 PM
russelbit
Oct 22, 2009 12:39 AM
muffak
Sep 16, 2004 09:36 PM
