gritty timing belt tensioner?
Old Mar 7, 2006 | 09:37 PM
stevescivic's Avatar
Default gritty timing belt tensioner?
Well tonight I decided to change out my timing belt on my crx and I got this brilliant idea of cleaning my tensioner with brake cleaner. I didn't spray directly into the bearings but sort of all the expose metal that is visible to the eye. I cleaned off a LOT of dirt and grease and although my tensioner has absolutely no play it does feel a tiny bit gritty after the cleaning. I think I may have put a bit of dirt into the bearing but I'm not sure if I should even be concerned.
It makes no noise when running and actually is quite quiet.
Suggestions?
Old Mar 7, 2006 | 10:24 PM
ED7's Avatar
ED7
Default Re: gritty timing belt tensioner? (stevescivic)
Should have put a new one on with the belt. Who knows if it will continue to be ok? Best bet is a new one, or if it seems ok to you, just leave it.
motegicivic
Oct 16, 2011 08:17 PM
airikkCRX
Apr 2, 2010 08:29 AM
SPIKE'S91CIVICSI
Mar 9, 2009 03:11 PM
5thGeneration
Nov 19, 2007 02:19 PM
JDM_Andrew
Jan 16, 2006 03:30 PM
