CAR NOT STARTING NORMAL?
Old Mar 7, 2006 | 08:37 PM
don24's Avatar
Default CAR NOT STARTING NORMAL?
WHEN I START MY 92 CIVIC CX UP IT ACT LIKES IT NEEDS MORE FUEL TO STAY RUNNING BECAUSE IT WILL START CUT OFF,START CUT OFF,THEN I GIVE IT A LIL GAS IT STALLS AND RUNS WHEN IT GET ENOUGH FUEL ITS SEEMS,SO I CHECKED THE FUEL FILLTER ITS GOOD.
WHAT ELES COULD I CHECK ???????????? SO WHAT DOES IT SOUND LIKE TO YOUALL
I NEED THE HELP PLEASE IDEAS OPEN
Old Mar 7, 2006 | 08:42 PM
SpydiR's Avatar
Default Re: CAR NOT STARTING NORMAL? (don24)
1.] re-read the title of your post.
2.] turn off your effing caps
3.] I had this happen to me, but it turned out to be my chipped ECU frying. I spent over $350 on parts before I figured out the problem though, so good luck.
Old Mar 7, 2006 | 09:02 PM
wheelmanbg's Avatar
Default Re: CAR NOT STARTING NORMAL? (SpydiR)
try cleaning the points on your distributor
Old Mar 7, 2006 | 09:18 PM
cxtengoku's Avatar
it could b ur efi main relay...can u hear the fuel pump prime when u put the key into the on position?
Old Mar 7, 2006 | 09:40 PM
hyperforming's Avatar
if it starts it is not a starting problem it is an idle problem. it could be alot things timming, tune up spark plugs and wires cap, rotor i was going to say fuel filter do a basic tune up if it has not had one in a few years then go from there. that is just my advice trouble shooting the car would be better for any one to tell you specificly what is wrong. a vacume hose may have cam off or rotted ? many things
Old Mar 7, 2006 | 11:50 PM
Contender25
Guest
Posts: n/a
Or it could just be weak fuel pressure and you're fuel pump about to die. Me and my buddy had the same problem in his hatch and tested the fuel pressure, turns out it was lower the usual, so we changed it and no more bs.
steven83r
Oct 21, 2013 07:21 AM
dsturch1
Oct 15, 2007 10:47 AM
SoCal ITR
May 6, 2004 10:27 PM
Magick211
10
May 1, 2004 09:44 PM
ABTDer
Oct 30, 2003 06:30 PM
