B16B swap
Old Mar 7, 2006 | 08:18 PM
jserman's Avatar
Default B16B swap
I just bought a 88 CRX DX and I happen to stumble across a B16B so I will be putting it in the CRX..
Has anyone done this..
any advise and anything special I Need to now... like parts and what not..
thanks
Old Mar 7, 2006 | 08:25 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: B16B swap (jserman)
Swap wise its same as any other B.
search up as slight things will change if you are using a hyrdo tranny.
Old Mar 7, 2006 | 08:27 PM
VtecSyndrome's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jserman &raquo;</TD></TR><TR><TD CLASS="quote">I just bought a 88 CRX DX and I happen to stumble across a B16B so I will be putting it in the CRX..
thanks</TD></TR></TABLE>
Of course somebody has done that, just use the search and find all the info you need to swap a b-series into a EF chassis since it's that common.
Old Mar 7, 2006 | 08:34 PM
jserman's Avatar
Default Re: B16B swap (VtecSyndrome)
yea I did a search on B16B and CTR but got nothing...
sorry I am new to the whole engine swap thing...
and yes I will be using the Hydro trans
Old Mar 7, 2006 | 08:41 PM
Ass$nyper's Avatar
https://honda-tech.com/zerothread?id=1508680
FAQ has a bunch of write ups on B swaps.
What obd do you plan on running?
you will need to order mounts for the hydro then.
Old Mar 7, 2006 | 08:48 PM
jserman's Avatar
Default Re: B16B swap (*** Sniper)
Yea I have been told I need some extra stuff.. I found some stuff on B18A swappa just wanted to make sure there wasn't anything else I needed...
I don't now what obd yet I have to wait to see the ECU because it might be a obd1 since it is coming fomr japan I heard the converted to obd2 like after 2000..
like I said I am new so I am trying to learn all I can
Old Mar 7, 2006 | 08:52 PM
Ass$nyper's Avatar
learning is good and that FAQ is a wealth of info.
Just spend some time reading there any snags post up and we are here to help.
You don't have to use the OEM ecu but it is obd2 and you will need to do some wiring.
Contact rywire or boomslang if you want to buy a harness or search if your a diyer.
Old Mar 8, 2006 | 04:38 AM
StorminMatt's Avatar
The 1996-1997 JDM ECUs are basically just OBDI ECUs with OBDII plugs.
Old Mar 8, 2006 | 11:54 AM
drachir's Avatar
B16B only ever came with hydro tranny. You'll need a hydro conversion kit.
Other than that, it's the exact same as any other b-series swap. Make sure you have the correct driver's side mount - you need one from a first gen b-series.
Old Mar 9, 2006 | 10:25 PM
jserman's Avatar
Default Re: (drachir)
you mean motor mount for the front... does this not come with the mount in the kit??
Old Mar 10, 2006 | 04:25 AM
jay-tec's Avatar
Default Re: (jserman)
man i would swap that beast in w/ a cable b16 tranny. you would need a clutch for a cable tranny too then. i would just wire it for obd0 or 1. obd-0 you could go with a pr3 or pwo ecu. obd1 you could go with a p72, p28 or even a p13. dont do the ond2 its a pain in the *** and the wiring sux. make life simple
Old Mar 10, 2006 | 04:29 AM
Default Re: (jay-tec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jay-tec &raquo;</TD></TR><TR><TD CLASS="quote">man i would swap that beast in w/ a cable b16 tranny. you would need a clutch for a cable tranny too then. i would just wire it for obd0 or 1. obd-0 you could go with a pr3 or pwo ecu. obd1 you could go with a p72, p28 or even a p13. dont do the ond2 its a pain in the *** and the wiring sux. make life simple </TD></TR></TABLE>
Wiring a 1996-1997 JDM ECU is no more difficult than wiring a P28/P30/P72.
Old Mar 11, 2006 | 09:51 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jay-tec &raquo;</TD></TR><TR><TD CLASS="quote">man i would swap that beast in w/ a cable b16 tranny. you would need a clutch for a cable tranny too then. i</TD></TR></TABLE>
As long as he gets a ys1 (92-93) cable tranny then the hydro clutch will also work, they are the same spline count on 92-up B-series. If he got a '91 or older B16 trans then he would need a different clutch than what the hydro tranny would use. just go with a ys1 since it will bolt right up
w/o the use of a conversion kit, factory is so much nicer IMO. and if you want you could even swap over the CTR gears right into the ys1 since they are the same size case.
Old Mar 11, 2006 | 03:38 PM
jacoop86's Avatar
Default Re: (VtecSyndrome)
honda tuning mag did this swap aug 2003.
"One Favorite Meets Another
A CRX Type-R? Fantasy becomes reality."
http://www.hondatuningmagazine.com/toc/0308ht_toc/
i have this copy handy, if you need anything spicific let me know. ill try to help you out. mabey you could back order it or something. if i had a scanner i would copy it for you....
Old Mar 11, 2006 | 04:09 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: (jacoop86)
Its no big deal installing a b16b, pretty much like any other b series except deciding to run a cable or hydro tranny, and what electronics to run. Here's what i have for mine:
Running OBD1 electronics on a chipped p28 with a frog harness
And i went with a jdm YS1 with lsd model:
Modified by Deetz at 6:25 PM 3/11/2006
Old Mar 11, 2006 | 04:23 PM
si0385.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jserman &raquo;</TD></TR><TR><TD CLASS="quote">I just bought a 88 CRX DX and I happen to stumble across a B16B so I will be putting it in the CRX..</TD></TR></TABLE>
lucky bastard
im suprised peter of ryan from rywire didint find this thread yet... if you contact them on there site http://www.rywire.com they will head you in the right direction
Old Mar 11, 2006 | 07:24 PM
Ben Ogle's Avatar
Default Re: B16B swap (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">The 1996-1997 JDM ECUs are basically just OBDI ECUs with OBDII plugs.</TD></TR></TABLE>
Hmmm I dunno why you would say that. I'd like to see one with a 66301/201/207 in it.
Ben
Old Mar 12, 2006 | 01:18 AM
FOMULA91's Avatar
Default Re: (Deetz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz &raquo;</TD></TR><TR><TD CLASS="quote">
[/i]</TD></TR></TABLE>
HEY, your axel is leaking grease.
Old Mar 12, 2006 | 03:13 AM
Default Re: B16B swap (Ben Ogle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ben Ogle &raquo;</TD></TR><TR><TD CLASS="quote">
Ben</TD></TR></TABLE>
Well, I guess I meant that from a sensor and error code point of view. Clearly, the electronics are different.
rextoration
Dec 7, 2010 01:59 PM
K20ISR
Apr 9, 2008 05:08 PM
ShocK
Sep 5, 2007 02:01 PM
m3talc0re
Mar 24, 2005 01:46 PM
KOME
Jun 12, 2003 03:26 AM
