92 Accord EX AT problem
Old Mar 7, 2006 | 07:25 PM
Luv those Hondas's Avatar
Default 92 Accord EX AT problem
Where do I begin? I hope someone out there has had this same problem and can give me a solution. When my car warms up after 10 or 15 min the trans acts like it is in neutral. If I let the car cool down it shifts fine until it heats up again. The Honda Techs ( my friends ) say I need a new on rebuilt TCU. HELP!!! before I spend way too much $$$$.
Old Mar 7, 2006 | 07:34 PM
BLKFLSH's Avatar
Default Re: 92 Accord EX AT problem (Luv those Hondas)
If your D4 light is lit, when it shouldn't be. TCU is probably the problem. If you could open up the box and look inside you could confirm this. There would be black stuff leaked from capacitors on the circuit board.
Old Mar 7, 2006 | 07:36 PM
BLKFLSH's Avatar
Default Re: 92 Accord EX AT problem (BLKFLSH)
If you buy one from the dealer it will cost you a bundle of $$$$$. So you may want to try and find a used or rebuilt one. Good luck.
Have you tried to get the code from the TCU?
Old Mar 7, 2006 | 07:41 PM
gianinline's Avatar
Local junkyard.... specially those where you get the part you need on your own "risk"!!
Old Mar 7, 2006 | 07:47 PM
P_Adams's Avatar
If after 15 minutes, the trans drops out of gear and won't move; I'd be hard pressed to condemn the TCM on this one.
If, what you're saying that after 15 minutes you've got 1st and reverse, then yes; you've got engagement, but it won't up-shift (then yes it could be the TCM) but
If you have no engagement, most likely it's internal to the transmission (you're loosing pressure).
This is not a fly-by-wire system; the shift control cable actually engages the trans, the TCM controls shift function.
Have you checked the fluid for both quantity and contamination?
My '88 wouldn't up-shift cold, and a trans flush took care of it. But yours is completely opposite.
P
Old Mar 7, 2006 | 07:53 PM
Dmc1's Avatar
Do you live in southern ohio?
I live in northern kentucky I have a tcu and a good trans just pm me I could swing by and plug in the spair tcu to see if it helps
Old Mar 7, 2006 | 08:26 PM
No leakage inside TCU.
Old Mar 7, 2006 | 08:28 PM
Default Re: 92 Accord EX AT problem (Dmc1)
I have no gears at all.
I have to Fred Flinstone the car.
Old Mar 7, 2006 | 08:29 PM
I live in central Ohio.
I got a uased one someone said was good and it also didn't work.
Old Mar 7, 2006 | 08:34 PM
Default Re: (gianinline)
I'll try and get a code from the TCU. It is 12:30am here in Ohio. So I'll let you know later.
Thanks for all suggestions!!!!
daughterscar
Mar 12, 2019 02:46 PM
jackliu2391
Nov 10, 2012 08:53 AM
collector_164
Apr 30, 2011 07:30 AM
beeasy12
Jan 1, 2011 05:46 AM
jsteezy1290
May 15, 2005 09:40 AM
