ATS/JDM/USDM stock ITR gearing and ATS 3,4 and 5 gears.
Here is Just some Gearing comparrisions for those That I see asking all the time Enjoy
(all figures are shown with a 8400 rpm Redline, and 195/55/15 tires)
the Mph indicated is the maximum speed possible with a 8400rpm redline for that gear
The Shift rpm is the RPM that will be had when shifted into that gear from the previous gear at redline.
Stock ITR
1st gear - - -41.2mph
2nd gear - - -63.2mph shift rpm 5474
3rd gear - - -91.3mph shift rpm 5818
4th gear - - -120.3mph shift rpm 6378
5th gear - - -157.0mph shift rpm 6435
RPM in 5th gear at 70mph is 3746
Stock ITR gearing with a JDM FD 4.786
1st gear - - -37.9mph
2nd gear - - -58.1mph shift rpm 5474
3rd gear - - -83.9mph shift rpm 5818
4th gear - - -110.6mph shift rpm 6378
5th gear - - -144.3mph shift rpm 6435
Rpm in 5th gear at 70mph is 4074
Stock ITR gearing with ATS 4.92
1st gear - - -36.9mph
2nd gear - - -56.6mph shift rpm 5474
3rd gear - - -81.7mph shift rpm 5818
4th gear - - -107.5mph shift rpm 6378
5th gear - - -140.4mph shift rpm 6435
RPM in 5th at 70mph is 4188
Now I will do the same three comparrisons but this time adding the ATS 3rd, 4th, and 5th gear set. (1.652, 1.308, 1.033)
ITR /ATS gearing with stock 4.4 FD
3rd gear - - -80.6mph shift rpm 6592
4th gear - - -101.8mph shift rpm 6651
5th gear - - -128.9mph shift rpm 6634
RPM in 5th gear at 70mph is 4563
ITR/ATS gearing with a JDM 4.786 FD
3rd gear - - -74.1mph shift rpm 6592
4th gear - - -93.6mph shift rpm 6651
5th gear - - -118.5mph shift rpm 6634
RPM is 5th at 70mph is 4963
ITR/ATS gearing with ATS 4.92 FD
3rd gear - - -72.1mph shift rpm 6592
4th gear - - -91.0mph shift rpm 6651
5th gear - - -115.3mph shift rpm 6634
RPM in 5th gear at 70mph is 5102
This was just Presented as a Guide into what differant setups's are available, i know I did not cover all possible setup's. and I only included a 195/55/15 tire (23.44 inch tire diameter) by addin differant size Tire's the possibility's are endless.
But now you can see some actual number;s instead of just what people say
- - - - - - - - - - Mike
Stock ITR
Thats useful inforamtion. I myself have been deciding whether or not to do a new FD maybe next winter. I keep hearing everyone say how worth it it truly is.
Need to run into a little more $$ though
That's strange. On my stock ITR tranny, shifting at redline gets me back into VTEC range for every gear. Below you list the 1-2 shift being at 5474 which would be out of VTEC range.
Or maybe I just shift faster than you
Stock ITR
has anyone driven a car with a 4.78 FD, and ATS 3,4,5 gears. IM me i would like to talk to you. or post your review here
here's a thought, what would it be if the overall tire diameter was 21.7 inch with just a stock ITR tranny with the JDM Honda FD(4.7)
what difference would it be?
[Modified by SANBST, 9:17 PM 3/31/2002]
well this would be your gearing
1st gear - - -35.1mph
2nd gear - - -53.8mph
3rd gear - - -77.7mph
4th gear - - -102mph
5th gear - - -133.6mph
rpm in 5th at 70mph is 4401
your shift up speed would be stock.
http://racingcraft.com/ats-gear-ratio-comparison.shtml ... here is the link to the chart on ats's page .... im going to do the ast 3/4/5th this summer, ill let you know how it goes. (i hope im not a fool)
With Stock Type R gearing what rpm are you at when you are going 60 mph??
Thinking of getting a type r tranny so just need to know a few things.
let me know
let me know
that is a small tire. smaller than a 195/45/15(21.9)
so correct me again, there would be a difference with 21.9 inch overall diameter?
thank you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tommy_Gunns »</TD></TR><TR><TD CLASS="quote">That's strange. On my stock ITR tranny, shifting at redline gets me back into VTEC range for every gear. Below you list the 1-2 shift being at 5474 which would be out of VTEC range.
I believe his calculations are off because he's using an assumed 8400 rpm redline (stock itr rev limiter = 8600). Many of us rev to 9200-9500 and that makes a difference in where the rpm's land on upshifts.
dc2r_integra
Aug 7, 2006 03:28 PM
