stereotypical idling problem help please!
Old Mar 7, 2006 | 05:10 PM
N1 Andy's Avatar
R.I.P. Andy
Default stereotypical idling problem help please!
I swapped a 96 dx motor into my 93 si for something reliable to get around till I get a better motor finished, I swapped engine harness, injectors, dizzy and ecu to obd-1 and the ecu is a p-05 or whatever cx ecu, I also put a obd-1 intake mani and t/b on it (I hate the obd-2 dx snorkel intake mani) everything is all good except the idle, it sounds like the usual backyard swapped civic; idles from 1500-2500, up and down, I know this is usually the IAC, I pulled off the iac and cleaned it out really good, no luck, maybe I have the wrong clip on it the wires going to it are yellow/black and blue/black, is that right? the only other clip it could be is the one I have hooked up to the evap emissions purge valve and those wires are yellow/black and red, there are no cel's. I bypassed the fast idle valve, could this also be a problem? Could anyone help me out? any ideas? It Idles perfect until its warm, then it starts idling erratically. Thanks!
Old Mar 7, 2006 | 06:12 PM
N1 Andy's Avatar
R.I.P. Andy
Default Re: stereotypical idling problem help please! (Slow Jdm EG6)
anyone?
Old Mar 8, 2006 | 06:24 AM
C_R_X_V_T_E_C's Avatar
Maybe the Fast Idle That You Bypassed, OR Maybe TDC Sensor. TRy It.
Old Mar 8, 2006 | 12:12 PM
N1 Andy's Avatar
R.I.P. Andy
Default Re: stereotypical idling problem help please! (C_R_X_V_T_E_C)
well, I un-bypassed the fitv and it runs great till the thermostat opens then all hell breaks loose again haha, Im gonna try and hunt down a new/used IAC and see if that helps, Im not paying $180 from honda for one. any suggestions?
JDM_CAM23
Aug 11, 2011 03:20 AM
Turbo_DelSol
Mar 6, 2009 12:39 AM
jdm civic 2000
May 21, 2002 08:41 PM
