EG with Integra real disk brakes
You *can* use a gsr master cylinder. However, I wouldn't recommend it though due to the ABS. You will have to re-align one of the brake hardlines in order to bolt up to the master cylinder.
I would recommend using a 94-01 Integra RS master cylinder.
The brake booster goes right in though.
Prop valve and everything else will work.
My friend is in the middle of putting 94 integra disk brakes on his 94 civic cupe. He hasn't done the master cylinder/booster yet. Is the 94-01 RS one a 15/16"? Also he would have to take out his porportioning valve and replace it with the RS one or one from a 90-93 non abs integra right?
Corksil
17
Dec 15, 2020 05:44 PM
MAFDARK
Suspension & Brakes
Apr 19, 2009 09:38 PM
