What did I forget to hook up?
Old Mar 31, 2002 | 08:27 AM
laughinxxx's Avatar
New User
Default What did I forget to hook up?
I just finished plumbing my intake manifold for a direct port kit and I got the manifold back on the next day. When I tried to fire it up I had two problems. At first it would start and then sputter out. That's fine, I saw alot of fuel on the manifold, so I tightened down the banjo bolt on the fuel rail and the car quit dying on me. However, now the engine revs from 3000 rpm to 4000 rpm at idle. I check the throttle cable and made it looser, so that's not a problem. My fuel pressure jumps from around 34 psi to 40 psi. What would cause this?
Old Mar 31, 2002 | 11:25 AM
DirtyLude's Avatar
Default Re: What did I forget to hook up? (laughin2.2)
Vacuum leak. Major one, too.
Old Mar 31, 2002 | 01:02 PM
laughinxxx's Avatar
New User
Default Re: What did I forget to hook up? (DirtyLude)
That seems to be what everyone on PO.com is saying too. What sealant do I need to use on the intake manifold gasket?
Old Mar 31, 2002 | 05:12 PM
migo's Avatar
New User
Did you re-placed the Intake Manifold gasket......Sound like a vacuum leak. Get a can of carburator cleaner and spray it around the Manifold to help you find your leak...
Old Mar 31, 2002 | 09:39 PM
laughinxxx's Avatar
New User
Default Re: What did I forget to hook up? (D.specs)
I replaced the manifold gasket, but I didn't use Hondabond on it, and I was really tired/weak when I was tightening everything down. My dad is going to give me a call the next time he has to swing through town, so that I can pull the intake manifold and reinstall it properly. If that doesn't work, we'll get to try to find what else I could have messed up.
Old Mar 31, 2002 | 09:43 PM
Accord94DX's Avatar
$2 says its your intake manifold gasket.
Old Mar 31, 2002 | 09:49 PM
laughinxxx's Avatar
New User
Default Re: What did I forget to hook up? (Accord94DX)
That's my guess as well.
Lilsoldierbenny
Apr 16, 2010 07:27 AM
EG6 Poe
14
Jan 6, 2008 01:32 PM
Curt91
May 24, 2007 05:22 PM
99GSRTurbo
Jan 2, 2007 04:17 PM
jdmeg61
Oct 29, 2006 08:12 PM
