wire tuck....car wont start
Old Mar 7, 2006 | 03:46 PM
Beau Gotti's Avatar
Default wire tuck....car wont start
sometimes it will want to turn over, but its like the battery is low, and i hooked it up to my prelude trying to jump it off. does the same thing. would it be a bad ground?
i just got done with my wire tuck, didnt removed anything, just pulled the harness inside the car, extened the headlights harness and moved down the frame rails, and they all work fine
is there something i possibly just have forgot to plug in, everything on the under hood fuse box looks good, its also inside the car.
everything on the interior fuse box is good
so that would leave me to think a bad ground somewhere, but where?
Old Mar 7, 2006 | 03:49 PM
onepoint6i's Avatar
Default Re: wire tuck....car wont start (Beau Gotti)
yup a bad ground
check the grounds and their contacts..they could have moved and is now touching paint..
check under the battery tray ground it goes from the body to the tranny...
Old Mar 7, 2006 | 03:50 PM
charliev's Avatar
hmmm im thinking check all of your grounds that go from engine-> chasis and check you ground for the battery... ohhhh and make sure battery terminals are tight..
Old Mar 7, 2006 | 04:12 PM
Beau Gotti's Avatar
and ideas on what grounds to check. the one from that goes from the body to the tranny that holds the terminal is on good the one on the coolant port is on. chassi to valve cover is on, what other ones?
Old Mar 7, 2006 | 05:06 PM
Beau Gotti's Avatar
pass. headlight thing with all the ground wires going to it isnt mounted on the frame rail yet. the headlights work, but could that be part of the reason?
Old Mar 7, 2006 | 07:24 PM
Rukusmasta2's Avatar
Default Re: (Beau Gotti)
u should have 3 at the thermo, tranny, valve cover, 2 on passenger inner fender, i think 2 too on driver inner fender, and i think thats it from the factory, you can also ad some more like me
Old Mar 8, 2006 | 09:39 AM
b.d.racing's Avatar
Default Re: (Rukusmasta2)
Nah dude the grounds for the headlights have nothing to do with it as far as I know. They just keep your headlights on. Its definetely a ground for the engine or some relay I don't know.
Old Mar 8, 2006 | 12:25 PM
Default Re: (b.d.racing)
i know they dont i was just sayin everyground in da engine bay itself
Old Mar 8, 2006 | 03:07 PM
Beau Gotti's Avatar
i got it figured out. it was one of the bolts on the starter, not the one that holds it on the tranny, but the long skinny one was missing. so i got it on there, and it cranks up fine. i guess those are used like a ground.
Old Mar 8, 2006 | 03:15 PM
wow thats wierd
evilho75
May 13, 2012 01:35 PM
civicex442
Dec 1, 2007 11:29 AM
96SIR
Dec 19, 2006 08:08 PM
philkehn
21
Jul 5, 2006 08:29 PM
92J-SpecHatch
18
May 1, 2006 06:42 PM
